Last Post: conv90
Last Post: Mad Max
Last Post: RKN
Last Post: Jason's Sporty
0 Good 2 into 2 exhaust?
Last Post: FearTheBeard
Last Post: Sportycus
5 Eye Protection When Riding?
0 Gravydog crashed again.
0 What color are your pipes?
0 Relocated Turn Signals
Last Post: 1Scooter
3 Shaky Dave Recovery
0 With this fit my 99
Last Post: jordan1200
0 1200s mid throttle stumble
Last Post: NZstu
Last Post: Kejobe
Last Post: Screw Loose Dan
Last Post: Rodzilla
Last Post: sprink
0 Happy Birthday wandrur!
Last Post: wandrur
0 New England 2018
Last Post: Boudwood
Last Post: tigger
Last Post: farmall
0 FS Stock 2012 Xl1200 and 1275 jugs
Old 23rd May 2018
Steven2142 Steven2142 is offline
Sportster/Buell Model: Xlc
Sportster/Buell Year: 79
Steven2142 is an unknown quantity at this point
Default Running Rich
I have a79 ironhead i just got it i think its running rich it back fires out of the rear cylinder an smells like gas at the carb while running it has a sns super b carb on it not sheer what size jets it has in it guy i baught it from said it is punched over not sheer how much not sheer if it makes a difference in it running rich
Old 24th May 2018
Hexlobular's Avatar
Hexlobular Hexlobular is offline
Hexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant futureHexlobular has a brilliant future
Hang in there; give folks more than 33 minutes to respond to your questions. And, welcome to the Forum!
'06 Roadster, Stage One w/ Forward Controls, So. Indiana 学ぶ,分け合う,乗る
Old 24th May 2018
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Smells like gas is a good thing. Gas dripping Wetting the Engine. Not so much.
I run a B on my 1990. I run a Zenith Bendix on my 1980.
You learn the tickler yet? http://www.nightrider.com/biketech/d...als/superb.pdf
Got any pics? We all use https://imgbb.com/
As far as backfire and smelling like gas. You might use the link I gave you to learn how to adjust it.
B carbs are stupid simple to dial in and use. They are just glorified Linkhert carbs to me.
I run a 70 main jet and 29.5 intermediate on mine if that is any help. But mine is punched out 1200cc. You should be OK if you find a 68 or 69 main jet on your 1979.
All yours may need is adjustement. There is the idle mixture screw. Tickler should be down. Idle set at 1000 to be safe.
Here is 1980 build thread. http://xlforum.net/forums/showthread.php?t=2067738
You might get some maintenance ideas from it on what to look over on yours.
Edit. Use the search bar on the bottom of the forum. Use this search term in it
Ironhead intake leaks.
Might be a good start to figuring out why you are running rough. Besides the ignition side of things. Read the stickies in the iron head section also. You'll learn something.
2nd edit: Let's hope a mod moves this thread to the ironhead section. So it gets the attention it deserves. Next time you post a thread about your bike. Use the Ironhead section of the forum.
Howdy and Welcome.
Wish I was 17 again.
Traveled to
Old 24th May 2018
rokytnji's Avatar
Better snatch this up before it is gone.
Manual
