0 Keith Black Conversion
Last Post: 1HD4CJM1X4K
Last Post: conv90
Last Post: Mad Max
Last Post: RKN
Last Post: Jason's Sporty
0 Good 2 into 2 exhaust?
Last Post: FearTheBeard
Last Post: Sportycus
5 Eye Protection When Riding?
0 Gravydog crashed again.
0 What color are your pipes?
0 Relocated Turn Signals
Last Post: 1Scooter
3 Shaky Dave Recovery
0 With this fit my 99
Last Post: jordan1200
0 1200s mid throttle stumble
Last Post: NZstu
Last Post: Kejobe
Last Post: Screw Loose Dan
Last Post: Rodzilla
Last Post: sprink
0 Happy Birthday wandrur!
Last Post: wandrur
0 New England 2018
Last Post: Boudwood
Last Post: tigger
Last Post: farmall
Old 24th May 2018
valvebeater valvebeater is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1975
Other Motorcycle Model: FLH
Other Motorcycle Year: '82
valvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of light
Here ya go. the fender is cut at one strait cut at an angle of 66 degrees from horizontal and bottom edge is 1 1/16 " aft from the centerline of the rail bolt. The holes in the fender appear to be oval shaped. The large fender washers inside at front holes also look ovaled and appear to be permanantly attached to the fender.
Old 25th May 2018
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to behold
Thanks again Valvebeater.
Mr Wolf, does this jive with the stock piece you have? is it just a straight cut across, or should there be a rolled edge similar to front fenders?
Old 25th May 2018
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Sportster XL
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant future
It is a clean cut. The main difference between cutting off a fender and the oem piece is the inner brace on the oem piece.
If I could only live at the pitch that is near madness
When everything is as it was in my childhood
Violent, vivid, and of infinite possiblilty:
That the sun and moon broke over my head.--Richard Eberhart
Old 25th May 2018
Moon Wolf's Avatar
BTW, real front fenders don't have a rolled edge. They have a 90 degree lip.
