0 Front cylinder noise
0 I'm going nuts (Adjusting Fuel Mixture)
Last Post: Another.Mike
0 mid controls
Last Post: kitster
0 little rock
Last Post: kitster
0 Clutch issue
Last Post: kas
0 900 dual carb front head
0 Ignition question
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 1200S cam comparisons
Last Post: Saint666
0 New acquisition
Last Post: heyshott 81
Last Post: paulc
5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: Slytat
0 lucas oil additive....
0 Runs rough on highway.
0 Tires for "Rubber mount XL" poll.
Last Post: Bryan83taco
5 Summer time heat
0 Oil Dipstick with Temperature Gauge 63023-05
Last Post: Jarlaxle
0 Bendix / Zenith questions
Last Post: The Doctor71
0 Lacing a 21 inch wheel to a 19 inch hub
0 What is the best '70's Ironhead to restore
0 Modified heads
Last Post: mrmom9r
Wild One, Bugs (66), Blazer (63), OnDVirg (63), Buggyboy (60), TheChimp (45)
Old 26th May 2018
1980SPORTSTER 1980SPORTSTER is offline
Sportster/Buell Model: Sporster
1980SPORTSTER is an unknown quantity at this point
Default Brake light stays on
I have a 1980 sportster that the brake light will not go off. When I remove both wires from the rear switch, both still have power going to them. Is this a short in the system?
Old 26th May 2018
sportsterdoc's Avatar
One of the wires is the power which feeds front and rear switches.
The other wire is the switch leg, which is fed by both front and/or rear switches.
Likely the front switch is remaining closed
Old 26th May 2018
jammantoo's Avatar
jammantoo jammantoo is offline
foot in mouth member
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
Other Motorcycle Model: Dou-glide
Other Motorcycle Year: 63
jammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond repute
You need to do a continuity test on each brake light switch. disconnect the wires to the switch and test it, the one that still has continuity is bad.
cheap continuity tester at home depot around 6 bucks https://www.homedepot.com/p/Sperry-C...FUN6Ygod3osAHw
Join the PEANUT CLUB, it gives you an excuse to stop and smell the roses
Old 26th May 2018
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Yep. Shorted by another hot wire.
Traveled to
Old 26th May 2018
Yakcm2's Avatar
Yakcm2 Yakcm2 is offline
Sportster/Buell Model: XLS 1000 Roadster
Sportster/Buell Year: 1982
Yakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond repute
Also might as well start with testing front switch first...
Almost always that one causing this problem, had the same on my 82, good luck.
and that's my 2cents worth...
Old 26th May 2018
rejeanprimeau's Avatar
Broken switch nub in the front housing.
Old 26th May 2018
45Brit 45Brit is offline
Other Motorcycle Year: 1975
My 92 XL had the same problem with the front switch. Just dismantled and reassembled it a couple of times, seems fine now
Old 27th May 2018
I will check the front switch this weekend. Thanks for all the information on fixing this issue.
Old 1st June 2018
Jcolleyoh's Avatar
Jcolleyoh Jcolleyoh is offline
Sportster/Buell Year: 2014
Sportster/Buell Model #2: XL1200CP
Sportster/Buell Year #2: 2012
Other Motorcycle Model: Fat Bob, KTMs & Vintage
Jcolleyoh is an unknown quantity at this point
Did you push on the front lever (forward) to make sure that doesn't make the brake light go off? Old, gummy fluid can inhibit it from opening the switch. Had that problem with my Fat Bob.
2014 XL1200C, 2012 XL1200CP and Fat Bob along with old dirtbikes, Vstrom, Bandit, etc.
