Last Post: conv90
Last Post: Mad Max
Last Post: RKN
Last Post: Jason's Sporty
0 Good 2 into 2 exhaust?
Last Post: FearTheBeard
Last Post: Sportycus
5 Eye Protection When Riding?
0 Gravydog crashed again.
0 What color are your pipes?
0 Relocated Turn Signals
Last Post: 1Scooter
3 Shaky Dave Recovery
0 With this fit my 99
Last Post: jordan1200
0 1200s mid throttle stumble
Last Post: NZstu
Last Post: Kejobe
Last Post: Screw Loose Dan
Last Post: Rodzilla
Last Post: sprink
0 Happy Birthday wandrur!
Last Post: wandrur
0 New England 2018
Last Post: Boudwood
Last Post: tigger
Last Post: farmall
0 FS Stock 2012 Xl1200 and 1275 jugs
distributor, ironhead, tachometer, unit
  #31
Old 27th May 2018
kaveebee's Avatar
kaveebee kaveebee is offline
Sportster/Buell Year: 1968
Other Motorcycle Model: kawasaki z1
Other Motorcycle Year: 1973
kaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant future
Originally Posted by sleighcrane View Post
Finally someone to share my pain. ........... Good luck
That Turtle Tank looks good. How about a shot of the whole bike?
Old 27th May 2018
sleighcrane's Avatar
sleighcrane sleighcrane is offline
Sportster/Buell Year: 1967
Other Motorcycle Model: FLHTK
Other Motorcycle Year: 2010
sleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nicesleighcrane is just really nice
Ok here’s a fairly recent one. Qualicum Beach 2018
Old 27th May 2018
kaveebee's Avatar
Now you're talking. They balance each other out well, the tank and the nacelle. The seat and exhaust help give it that classic H look.
Old 27th May 2018
BrokenIron BrokenIron is offline
Sportster/Buell Year: 1970
Sportster/Buell Model #2: '70 xlch
Other Motorcycle Model: Yamaha XS650
Other Motorcycle Year: '80
BrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura aboutBrokenIron has a spectacular aura about
Originally Posted by brianbbs67 View Post
Well you w
ere given the correct answer early in this thread and don't know why you ignored it. Hard spot to photo on a running bike.
IMG_0916 by brianbbs67, on Flickr
What answer was I given? And why sound rude about it? Did I not thank everyone enough? ( one more time ..)
THANK YOU!!!!!!
And I see that it’s not a huge, Noticeable piece..
However, with the trouble I’ve had just trying to get the factory speedo to work, dunno if I even want to deal with a similar piece. I think I may go to the bicycle style, I.e. electric...
So thank you again for your help, I’ll post back with pics of what I come up with
Old 27th May 2018
That is a true beauty! I’m not a “stock” guy, but that’s beautiful!
Great job!
Old 27th May 2018
There are many. Do a Google search for free photo host. Here's a couple, there may be better...
https://postimg.org/
http://www.picturetrail.com/
I know huh, google is my friend.! I was just mindlessly rambling with my fingers, anyway, thanks for the links and thank you for everything you’ve helped with on this bike over the last year... I get my google on, on the regular !
Old 1st June 2018
drumbrake drumbrake is offline
Sportster/Buell Year: 1972
drumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the roughdrumbrake is a jewel in the rough
I took this picture from one of my big twin parts catalogs.
I think it is a better picture of the tach drive cover assembly.
At least it seems less confusing than the Sportster catalog picture.
Old 1st June 2018
I found this interesting.
It seems like a good solution for putting a tach on a timer bike without the tach drive timer cover, or clearance for a cable etc.
I have never seen a Smiths style electric tach so you have to use the 70's style or newer, but it is bolt on and you don't have to modify anything on the bike.
Get a Superglide tach,a dual gauge mount and some wire and your good to go.
As far as I know all shovelhead superglide tachs were electric, nosecone shovelheads never had a place for a mechanical drive.
I learned the following from my 74 Superglide,
The 74 and 75 Superglide tachs ran from a wire from the voltage regulator, the signal for the tach came from the alternator.
This is a alternator signal tach, you can see one terminal says alt and the other is ground.
The 3rd terminal toward the bottom is also a ground it's the case ground for the illumination light.
This one will not work off of the ignition on any bike. It will only work with the matching alternator (a 12 pole) and regulator, Shovelhead.
[IMG][/IMG]h
This one is a 76 and newer. The TRIG terminal connects to the points (timer) side of the coil and the other should go to the IGN terminal on the ignition switch. The third one on the bottom is also ground for the light.
It is set up for one spark per revolution.
It's pretty easy to spot a Superglide (electronic) tach, they all have the big black dot on the face. The Sportster mechanical drive doesn't have that.
The back is what makes the difference.
71-73 Superglides didn't come with a tach.
71&72 had the FLH dash and big speedometer.
73 had only the small speedometer.
A tach might have been an option in 73 but none of the books I have show it.
I know this is a lot of big twin stuff but it might help someone trying to use one of these tachs on a sportster.
I got my tachometer on eBay several in fact. I had the best luck with ones that were a little bit older style and the stock light bulb assembly worked with it as well. The newer version worked but had the same problem with them getting erratic after a few miles . I haven’t checked them since I changed my power source. These are two different types I used with the older one working for me as well but it’s a little dirty inside
Old 3rd June 2018
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Originally Posted by mrmom9r View Post
Whoever told you it's on the top of the dist. is right. You don't have the right cap.
The tach drive caps are getting hard to find ,but they do pop up on ebay from time to time.
Originally Posted by Magneto Sportster View Post
Mrmom9r is correct. The tach on a 1970 model attaches to a drive in the top of the timer. If your cap doesn't have the drive, you have the wrong cap.
Originally Posted by BrokenIron View Post
Could someone please post a pic of this Timer cap with a spot for a Speedo drive? There is not one pic on the entire internet?? I’ve seen 10-12 different bikes, same year, all have same distributor that mine has, all have this flat top? What in the short and fkn curlys is going on? It can’t be this...wait, it’s an Ironhead, yes it can...
This is what I meant. You got 2 answers and ignored them and I got you a crappy but illustrative pic and you ignored the first posts to you thread, even when I confirmed them.
Ok, now I'm revived
