0 Keith Black Conversion
Last Post: 1HD4CJM1X4K
Last Post: conv90
Last Post: Mad Max
Last Post: RKN
Last Post: Jason's Sporty
0 Good 2 into 2 exhaust?
Last Post: FearTheBeard
Last Post: Sportycus
5 Eye Protection When Riding?
0 Gravydog crashed again.
0 What color are your pipes?
0 Relocated Turn Signals
Last Post: 1Scooter
3 Shaky Dave Recovery
0 With this fit my 99
Last Post: jordan1200
0 1200s mid throttle stumble
Last Post: NZstu
Last Post: Kejobe
Last Post: Screw Loose Dan
Last Post: Rodzilla
Last Post: sprink
0 Happy Birthday wandrur!
Last Post: wandrur
0 New England 2018
Last Post: Boudwood
Last Post: tigger
Last Post: farmall
Old 11th May 2018
mattjs666's Avatar
mattjs666 mattjs666 is offline
Sportster/Buell Model: XL883C
mattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the roughmattjs666 is a jewel in the rough
Default Bars on C Riser?
I want bars that are a bit higher but also to keep the riser on the 04-06 riser that comes on the 'C' models.
I like the chumps/ mini apes but not sure about the look of them on that riser.
Anyone got pics of higher bars on the C riser?
Old 27th May 2018
Subscribing Biker
These are 8" Chumps
Last edited by Toejam503; 24th August 2018 at 23:24.. Reason: Removed surplus img tags
Old 27th May 2018
mattjs666's Avatar
Those look nice. Thanks!
Did you have to swap all of the cables out ?
Sent from my SM-G960U using Tapatalk
Old 27th May 2018
Folkie Folkie is offline
I think higher bars on the Custom riser look a bit odd. Bite the bullet and swap out the riser:
I didn't have to swap the riser; my Custom came like that from the factory.
Old 27th May 2018
Subscribing Biker
I didn't have to swap anything but I rerouted the wires under the tank and bent the soft brakeline straight. After a week of riding, I decided that it didn't look clean enough so I ordered a 4" wire extension kit (Novella) from Dennis Kirk and a 4" longer single Brakeline from them also. The throttle cables are routed behind the triple tree and the clutch cable was plenty long enough. P.S. I like that CUSTOM 5" riser, it has a definite COOL factor !
Old 24th August 2018
mattjs666's Avatar
Thanks for the responses, ended up keeping the riser to see how I like it I can always remove it later but I like it there so far. Ended up switching out the brake line extended the wiring for the controls, then later the clutch and throttle cables but only because they were in rough shape.
Subscribing Biker
I think they give it a 70's look. You'll have to post a pic.
mattjs666's Avatar
Oh I did but the links didn't work I'll try it again
Old 25th August 2018
Subscribing Biker
Looks great and it puts the mirrors right where you want them. Lotta guys say they don't care for that riser but I think they have a definite COOL factor.
Graywolf Graywolf is offline
Not rubber mount and on a springer, but they work the same with any front end. Straight risers with sweeper bars.
Graywolf
