0 question on engine temp in winter
Last Post: AECS
0 04 XL1200 Burning Oil (possibly)
0 1200s mid throttle stumble
Last Post: Lethal
0 My 1200 IRON
Last Post: SCarty
0 ***DK Custom-Limited Time 10% Savings Code on ALL DK Custom Parts***
0 Air quality went down the tubes
Last Post: RandyMac
0 T-Bar Question
Last Post: DFuller1980
3 Thoughts on buying
Last Post: Medicalweed
0 How stock is your bike
Last Post: Beelzeboss
0 WTF Happened
0 Turn Brake Stop for 97?
Last Post: davidfite1978
Last Post: 8ball
Last Post: newroadster
0 Relatively Interesting Road Sign
0 Cast or forged
Last Post: spacecoast
0 WTB Rubbermount Air Shifter,Wheelie Bars
Last Post: Sprtstr1200s
0 Cam timing and piston position
Last Post: Pezed
0 Who's still riding???
0 New member in Pullman Washington
Last Post: Dustpan63
0 Quick and probably stupid question
Last Post: littlelisac
0 New England 2018
Last Post: tvon
Last Post: spoon
0 Metal Polishing
0 Let's See Them R's!!
Last Post: Bstrdbike
gp9739 (74), danbango (71), andyman1958 (60), 55 Jr (57), Love2FixIt (49), keywan (47), C Dubya (44), CA71xlch (43)
Old 24th May 2018
KCinSB KCinSB is offline
Sportster/Buell Year: 1965
Other Motorcycle Model: '69 TR6, '67 BSA, TR6C
Other Motorcycle Year: 1970
KCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to beholdKCinSB is a splendid one to behold
Question Did you go back to an OEM plungers seat? Like it?
If I do in fact get this long stored '65 XLCH to run, maybe a 50/50 chance, (OH'd mag came back yesterday!), I'm thinking the 1st change might be to get rid of the seat and go back to the factory spring plunger seat. Has anyone here done the "return to stock" work? Did you like it? maybe a hare-brained idea,...... Just never had one.
Old 24th May 2018
doodah man's Avatar
mrmom9r produces those parts, you should contact him...
http://xlforum.net/forums/showthread...readid=1585479
Old 24th May 2018
I went from a 70's cobra seat,i've had several over a 30 some yr. span,to a sprung solo seat using mrmom's assembly.i have zero regrets.looks much more like early '60s.
Old 24th May 2018
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Sportster XL
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant future
I find the solo seat with plungers the most comfortable option. It might be different, though, for someone much over 5'10". Recently I went on a three-hundred mile run and could have easily gone twice that.
Check your frame tubes--the two that support the seat yoke. Often times, these will be broken, modified, or damaged in a way that will not allow you insert the springs and/or bushings.
Mrmom9r's set is not compatible with the stock seat bracket, but they are excellent parts if you aren't aiming for 100% originality. We installed a set on a 69 CH and were well pleased with quality and performance. Additionally, it's a much cheaper alternative to sourcing the original parts.
If I could only live at the pitch that is near madness
When everything is as it was in my childhood
Violent, vivid, and of infinite possiblilty:
That the sun and moon broke over my head.--Richard Eberhart
Old 25th May 2018
Encouraging info! Thanks, and I will get in contact with him.
Old 25th May 2018
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to behold
Check inside your tubes first. Besides the fact of checking tube condition, it wouldn't be the first time the springs were left in there when owner changed the seat.
Old 25th May 2018
stalkie's Avatar
stalkie stalkie is offline
Serial Fettler
Sportster/Buell Year: 1970
Other Motorcycle Model: Triumph T120,TR6+3 BSA's
stalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond repute
You won't regret it, mine's very comfortable. If you're short it may not be so good.
Old 25th May 2018
my frame had some casting flash inside one of the down tubes.used a 13/16'' drill bit to remove it.iirc.
Old 26th May 2018
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
They are a bit of a compromise for me. I am 6 foot and the riding position is a bit "cramped" and I think I look a bit "strange" when riding it. Put it this way - I would naturally be sitting a lot farther back on a bike. Farther back and lower actually is a much nicer position.
But the seal looks so good on my bike I can't take it off.
I am considering putting another one on my 58 CH as I have a seat. But I'm missing the plunger setup and would go with MrMom's kit if I do go that way.
