0 Throttle Cable help needed
Last Post: dodgetrucken
Last Post: Brad
5 Do you have a Facebook Acct?
0 Broken chain
Last Post: ironbar
0 2018 Iron 1275 Project
Last Post: yelladox
0 04 883
Last Post: Brad
0 Gender sensitivity:
Last Post: Brad
Last Post: thecarfarmer
0 Rear Sprockets
0 Hello from Virginia
0 1250 or 1275 Pistons and Cylinders
Last Post: Turbo Sporty 48
0 My '05 1200C (insert clever title here)
0 Stock vs. Modified
0 V.o.e.s
0 Fixing or replacing primary cover for a 1975 xlh?
Last Post: Jberg93
0 Rocker arms bolts
Last Post: The Doctor71
0 83 XLH w/Velorex 562
Last Post: robbie202
0 Rubbermount Poll
Last Post: Newbeme
0 Headlight Modulator
0 1977 Sporster - Clutch ramp and ball assembly
Last Post: ironbar
0 cam clearance in cam cover bushings
Last Post: Jaime1840
max maxwell (73), hdphil (72), nsc (70), Tomo (66), harleychic (64), MA1 (58), sportynut (55), baka1969 (52), m0trh3d (48), edgeofinsanity, eyecandycustoms (41), SquidAEH37 (34)
ironhead frame swap
  #31
Old 23rd January 2021
84bobber's Avatar
84bobber 84bobber is offline
Sportster/Buell Model: Bobber chopper
Sportster/Buell Year: 84
Other Motorcycle Model: superglide
Other Motorcycle Year: 98
84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice84bobber is just really nice
What year frame did you use and other parts you used. I have a early 84 that I want to change over and get rid of my hardtail after market frame.. Thanks
4schizzle 4schizzle is offline
Sportster/Buell Year: 83
Sportster/Buell Model #2: Ironhead
Sportster/Buell Year #2: 73
Other Motorcycle Model: BMW R nine t
Other Motorcycle Year: 14
4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold4schizzle is a splendid one to behold
I bought an 1996 evo frame. The rear and lower front motor mount work. I made a top mount from an ironhead mount and the evo mount. I have pics posted on this discussion. I am running a sealed bearing hub. Using stock spacers and a flat rear sprocket.
84bobber's Avatar
Ok Great I am going to look for a roller and going to oil tank etc will keep in touch thanks again
Old 24th January 2021
84bobber's Avatar
883 or 1200 frame
84bobber 883 frame
45Brit 45Brit is offline
Sportster/Buell Model: XL
Other Motorcycle Year: 1975
I didn’t see the point of this bike when I saw the header, but it looks good!
paulc paulc is offline
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 74/5
I enjoy seeing builds like this, great work. Really like the overall look of this bike, everything goes together just right, great work.
Paul
Old 25th January 2021
I think the newer frame is a much better choice (stiffer/stronger).
i'm thinking the new motor isn't so bad either.
