swanny, Mrs Jimi, SnarleyHarley (72), ndulak52055 (67), ihjonny (65), fatchuk (64), provision (56), randreb (56), joeyhunter (53), junk runner jr (47), Pegscraper05 (44), cowboy_hamilton1@yahoo.co (43), wi1dwood (43) |
1st January 2022
Posts: 265 Sportster/Buell Model: XL Sportster/Buell Year: 1974
Regulator test 1974 xl
Hey guys, my generator light stays on. I have read the post about checking the charging system on the stickies, and for the regulator test it says to connect an ohmmeter to the orange and tan wires. The problem is that my wiring is not stock, it was made by someone else and it doesnt have the same colors. I took a picture from the regulator, does anybody know wich are the wires that I have to use for the test? thanks
https://i.postimg.cc/XJTv143m/regulatorxl.jpg
1st January 2022
Posts: 11,277 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
Top to bottom should be field, armature, and battery. So, middle and bottom terminals.
http://www.ruiter.ca/mc/info/PDFs/1R-116.pdf
2nd January 2022
Posts: 543 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 73 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
First thing to check for is a grounded generator indicator light. Remove all wires from regulator GEN terminal and keep wires away from grounding. Turn ignition on and if the light is on then the gen light is grounded. Refer to FSM page. 5-23
2nd January 2022
Great, thank you guys, I will keep you posted.
13th January 2022
Hey guys
I havent had the chance to test the charging system yet, but I forgot to mention something that could potentially be the reason why the battery is not getting charged.
I damaged my solenoid pretty bad while I was putting the bike back together, I was able to glue the stuff that got broken and it seemed to be working, but I couldnt really tight the positive battery cable, its just finger tight in there so I didnt break the conection again... what do you guys think?
Im also charging the battery to night to have it fully charged for tomorrow, Im using a battery charger that I borrowed and I think I set it up correctly but Im not a 100% sure If you guys could take a look it would be great, here are some pictures of how the solenoid was damage (Im ordering a new one) and of the battery charger:
https://postimg.cc/gallery/4JtTndf
thanks
15th January 2022
Anybody???
15th January 2022
So you know you need to replace the solenoid. The battery charger is set for 12v and 10 amps. The display shows 2.4 amps so I assume the charger is scaling back as the battery charges. Make sure the battery is not getting hot. The solenoid has several parts and different functions inside so please replace it. Any hand tight connections need to be made tight.
23rd January 2022
It turned out to be the solenoid...... My bad! I should of replaced it a long time ago, I got a new one and it's working perfectly... Thanks sungod
