0 an old Lady
0 Replacing Fork Springs and Fork Oil 'How-To'
Last Post: Mathias
0 1981 XLH Getting Recranked
Last Post: joe s
0 Fuel delivery issues
0 Factory Chain Oiler
0 Clutch Stud Spacer: 1.530" pn #5995, 0.040" #5996, 0.080" #5997
0 Align intake manifold
0 pop's through carb at,idle
0 ***DK Custom-2 NEW Contests-Instagram & Twitter***
Last Post: hannamontana
0 oil light flickering
0 DK Customs external Breather catch can location help
Last Post: tvon
0 Slip on muffler
Last Post: LiveToRide57
0 Fork Gaiters
Last Post: tiderider
Last Post: Stray Cat
0 Gas Cap problem?
Last Post: ZTatZAU
0 A different Oil filter test
0 23" wheel 4"over fork tubes
Last Post: class of 82
0 Saddlemen Step Up or Drag Specialties Predator III Seat?
Last Post: Mathias
0 All balls generator
Old 26th January 2022
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
A smear of gasket sealant on the bottom corner of the primary, on all four surfaces will be absolutely fine. You can also put little dabs of it around the edge of the primary face, on the engine side, this will help hold the gasket in place whilst you fit the primary cover.
You don't need to have a piece of card the same size as the primary cover to sit the bolts in.
This is a very good sealant - 9912 MANNOL RTV Silicone Sealant Black Gasket Maker High Temp Sealant
SonWon SonWon is offline
Sportster/Buell Model: Superlow 1200T
Sportster/Buell Year: 2016
SonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond repute
The light coat of axle grease will usually hold the gasket in place while you get a few of the screws started.
RandallM's Avatar
RandallM RandallM is offline
Other Motorcycle Model: Honda CM450
Other Motorcycle Year: 1982
RandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond repute
Turns out the "fork air control o-rings" part number lines up with the 2 screw chain inspection cover o-rings. They included 4, so you get two extra for down the road, so that's nice.
What about thread sealant like Loctite? Should it be used on primary cover bolts? It felt like there was some on them when I took them out.
1995 XLH 883 Sportster Hugger
NO. Use anti-seize. Loctite or Fel Pro C5-A.
RandallM's Avatar
OK, good to know. I have some Permatex anti-sieze, that's what I have always used.
That'll do.
There is not supposed to be any thread sealer used on the bolts.
The torque is only very small anyway and thread sealer will preload the threads.
Mine always go on dry and I have no leaks, no bolts backing out.
