Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 I need to polarize the generator each time I start the bike
Last Post: DR DICK
0 Vintage tires
Last Post: Nitro57xl
0 CV carb running way rich!
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
Last Post: Piper01
0 New to Harley - 2007 883R
Last Post: Mike1nw
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
0 ‘79-81’ rear wheel offset or spacing ing issue?
Last Post: bobandy
0 Help identifying brakes
Last Post: bobandy
0 Ignition advice
0 Down on oil
Last Post: Tipofthelake
Last Post: canoli
5 Harley T-Shirts
0 I was at the gym yesterday
Old 13th June 2014
purpony's Avatar
purpony purpony is offline
Sportster/Buell Model: Buell X1 Lightning
purpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to behold
Default rocker box bolt keeps snapping
I installed Buell XB rocker boxes on my Buell X1 a few years back and when i did the rear cylinder rear 1/4-20 grade 8 HD hex bolt snapped/sheered off on me. I have had my rockers off all winter and machined a drill guide and drilled this bolt out, and put a helicoil in the head. So i am installing the rocker boxes last night and torquing the bolts to spec and in the same location, the bolt snaps again!!! Im torquing them to what my service manual calls out - 10-14 ft/lbs. Pulled it all apart and lucky the way the bolt snapped I was able to just spin it out with pliers. Its a 1/4-20 grade 8 HD bolt and it snaps at 10 ft/lbs of tq, what gives?
Old 13th June 2014
cHarley04's Avatar
cHarley04 cHarley04 is offline
Sportster/Buell Model: XL1200C/1250
Sportster/Buell Year: 04
cHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant future
Just some thoughts/questions.
Are you sure the wrench is in calibration?
Torque wrenches are inherently not real accurate at the bottom or top of their range. For accuracy, you want to work in the middle of the wrenches range, not at either end.
For 10-12 ft/lbs, the better wrench choice might be something like a 20-250 IN/lbs wrench, torquing at 120-144 IN/lbs.
Are you using any extensions on the wrench and not recalculating for the extension factor?
Hammer 1250-Smash Heads-560 Cams -Hurricane Flow AC -Supertrapp Supermeg -TC88A
Old 13th June 2014
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
better yet are you bottoming out the bolt g8 bolts are pretty taught . as stated above good tq wrench are a must.
Old 13th June 2014
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
ft-lb torque wrenches aren't real accurate that far down the scale.
I use an in-lbs torque wrench and torque to 150 and they don't break.
Click Here to Contact Me
Old 1st August 2014
Wheelies Wheelies is offline
Wheelies is an unknown quantity at this point
The same happened to me on my front rocker box. I agree with the idea that torque wrenches suck at those low torque specs. My wrench clicked over fine on the rest of them but the very last one snapped off.
Old 1st August 2014
Folkie Folkie is offline
Torque wrenches are accurate at the top of the range, but not at the bottom.
Old 1st August 2014
rejeanprimeau's Avatar
I use a cheap beam type torque wrench ; never break bolt.
I love those clicker, I make money welding holes busted being over torque by clicker.
Keep clicking so we the machine shops and welders make money with your mistakes.
A 19.00$ sears beam type 3/8 is perfect for that job.
