0 Vintage tires
Last Post: Laconiatic
0 CV carb running way rich!
0 Koso hd-01-04 2014+
0 I need to polarize the generator each time I start the bike
0 Rear lights
Last Post: ironsquirrel
Last Post: Piper01
0 New to Harley - 2007 883R
Last Post: Mike1nw
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
0 ‘79-81’ rear wheel offset or spacing ing issue?
Last Post: bobandy
0 Help identifying brakes
Last Post: bobandy
0 Ignition advice
0 Down on oil
Last Post: Tipofthelake
Last Post: canoli
5 Harley T-Shirts
0 I was at the gym yesterday
Old 2nd May 2020
NoRemorse NoRemorse is offline
Sportster/Buell Model: 883
NoRemorse is an unknown quantity at this point
Default Wheels
Hi there.
I m always trying to lightweight ma cafe sportster, cause at milwaukee they seems to thinks that fat and weighty is nice
At this time my bike is around 220kgs. But I have a think I ve many kgs to lose on wheels.
Two ways : found some wheels and adapt them or put akront stuff and rear alloy hub...
Does anyone have done this job before? Any advice?
Old 3rd May 2020
Haegar Haegar is offline
Haegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud ofHaegar has much to be proud of
Default Wheels
Hi,
I saved around 8 kg when I switched to 2.5x18 and 3.5x18 aluminium rims with 100/90 and 140/70 Tyres. I'ive done some more diet and the actuell wheight is around 205kg dry.
You can save 6kg when you switch to a small Li-Battery and so on.
Here's a picture of my little racer.
Greeting from Germany
Christoph
Old 3rd May 2020
Wow 202 is f***g light..
I want to keep the 16/19 rims but it could save some kgs if I go alloy....
What s the ref. of your battery?
Thanks
Old 4th May 2020
My Battery is a JMT Lithium-Batterie HJTX14AH-FP . This is the type for 2004-up models where you have to build a new/smaller holder to fit in our frame. Save again some weight!
It's now over 3 years in the bike without any problems. I've never had to charge it after the winter.
Old 4th May 2020
I will look for that
Do you have photos?
Thanks very much
Old 4th May 2020
Hey haegar what was your method to measure the weight of your bike?
Old 24th May 2020
Merch131ho Merch131ho is offline
Sportster/Buell Model: XL1000
Sportster/Buell Year: 1979
Other Motorcycle Model: Merch 131
Merch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud of
Just to add that losing rotational weight and unsprung weight will be more noticeable than losing weight from elsewhere on the bike.
Rotational weight.. wheels, tyres, discs, sprocket.
Unsprung weight.. all of the above plus fork lowers, brakes, swingarm.. ie all the parts that are not supported by the springs of the suspension.
My own XL1000 special weighs 395 lbs dry, 420 wet.
The good news is that Harleys are built from heavy components (for good or ill) and so its fairly easy to drop 50 lbs, after that you have to work at it.
Old 25th May 2020
Thanks merch...
I m actually looking for some rims for my bike...
Old 21st June 2020
ducbsa ducbsa is offline
Sportster/Buell Model: XB12S
ducbsa is an unknown quantity at this point
What gas tank is that?
Originally Posted by Haegar View Post
Hi,
Christoph
