0 Handlebars
Last Post: 83ironman
0 Multiple timing marks?
Last Post: seajay
0 Riding in the rain
0 .551 Cams in an EFI 1200
0 Removing countershaft from access cover
Last Post: Russ
0 Anti reversion “muffler”
Last Post: JaKaL
Last Post: a-sad-anorak
0 question about new trans door
0 Where were the IronHead sportsters Made.
0 BMW reverse trike build
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 1200 conversion
vlmuke, wazza (48), Grizzwold (44), roaldtm (39), redtacoma31 (34)
Old 14th June 2012
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Looks like a fun bike will!!!!
Old 14th June 2012
HandOverFist's Avatar
Sportster/Buell Model: 1250-X
That's a barnburner of a 883 madnss! Lost the ability to edit the first post to record figures...pm'd a moderator to see if I can get it modified.
Old 14th June 2012
Sportster/Buell Year #2: 2008
I think it is a little more than 883.
Old 14th June 2012
That drag bike is actually a Buell S2 bodywork kit.
Is that Bob Draps bike Will?
Old 14th June 2012
It was not stated clearly in his post...all we have to go on atm is what is listed in his details.
Old 14th June 2012
madnss's Avatar
Originally Posted by madnss View Post
Factory stock 1992 tires, factory suspension, no air shift, no wheelie bars, 220lb rider with jacket, boots, helmet, no two stage rev limiter, no tach. Front end was strapped down with only about 2.5" of travel compared to the roughly 5.75" of factory travel. 91 octane pump gas from the local gas station. Factory 883 gearing.
Sorry, The bike is a 1992, bought it in january with 2500 miles. It has a HAMMER 1250 kit, xb crush ported heads, 15 degree angle dome in heads, mikuni 42, thunderheader, Hammer pushrods and screamin chicken 575 cams, dayton twin tec ignition. Still has the factory cone plate and factory dual fire coil, Bike has plugs and wires too. Thats it. No roller rockers or lifters.
This is not a costly build when considering head work in the mix. Thanks, Madnss
Old 14th June 2012
Thanks madnss...I'll update the list as soon as someone contacts me about modifying the thread. Anyone you can think of I can pm?
Old 14th June 2012
Well, the powers that be state it is not possible to edit the first post to reflect incoming results. They suggested a "google document", but I feel no need to jump thru hoops just to update a thread when I have done so on many other forums. Short story is I suppose this thread is destined to wither and die.
If someone else would like to pick it up that will be fine.
Old 14th June 2012
wandrur's Avatar
wandrur wandrur is offline
Thx for the help, jackass
Sportster/Buell Model: XL 883 > SE 1200
Sportster/Buell Model #2: 1200 XLH
Sportster/Buell Year #2: 1999
wandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond repute
Why don't you just quote the first post, edited it, and post a new comment with updated numbers and names? Just as easy and allows you to achieve your original goal.
Old 14th June 2012
madnss's Avatar
Originally Posted by wandrur View Post
why don't you just quote the first post, edited it, and post a new comment with updated numbers and names? Just as easy and allows you to achieve your original goal.
:d
