0 Deer hunting at stairman's.
0 What weight oil?
0 New users of Windows 10
Last Post: SLW210
Last Post: jump
0 69 oil pump breather timing mark
0 Ural quality testing
Last Post: Edster
0 Speed
Last Post: 1skullster1
0 Powerraythor conversion
0 RSD Rear-Sets for '04-'13 Sportsters
0 Cases Full Of Oil
0 Loose oil pump feed fitting - 2019 Iron
0 Vance and Hines RSD Tracker Exhaust
0 Blackstone HyperTek
5 What year is the most collectible Sportster.
Last Post: hhugger
0 Sprocket cover with chainsikle rearsets?
Last Post: Jason's Sporty
0 On starting a new thread
Last Post: kobra50
3 Shaky Dave Recovery
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
Old 27th April 2013
onebrkbstrd's Avatar
onebrkbstrd onebrkbstrd is offline
Sportster/Buell Model: xl1200l
onebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond repute
I'm going to take a look at the factory oil tank,, see if there's an atmosphere vent on it. If there's not I'll run like this and see what happens,, of there is I'll think of something.
Old 27th April 2013
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
Oh yeah that's right, you've got a custom oil bag happening there...
John from Windsor Ontario
'00 FXDL
Old 27th April 2013
Yep. Not worried about popping crappy glued seams in a plastic tank.
I looked at the factory tank,, nipples for feed, return, vent, and drain. None of those lines were vented to the atmosphere from the factory,, there's no odd contraption to vent the tank to the atmosphere that I can see,, and I don't recall the cap/dipstick being vented. I actually recall the damn thing sealing very tightly and being a pain in the ass to remove.
Now I just need the chainguard to dry so I can get it hung on there,, probably should adjust the chain a bit too.
Old 27th April 2013
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Ok, sorry, I'm still confused. So you're running an after market oil tank? And it's vented to atmosphere? All I know is that the cam chest and heads share the same air.....
"Only Fools Celebrate A Fool"
“Do the best you can until you know better. Then when you know better, do better.” Maya Angelou
Old 27th April 2013
xldukes xldukes is offline
Sportster/Buell Model: xl883c
Other Motorcycle Model: Harley Street Rod
xldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond reputexldukes has a reputation beyond repute
Ill see you there tomorrow. If you need help with anything just ask
Old 27th April 2013
Not trying to confuse. Yes,, I have an aftermarket oil tank. I have a 3 connections on it. Feed, return, and vent... Same as a factory tank,, except no drain.
A factory tank (to the best of my knowledge,, looking at the manual now) is not vented to the atmosphere, my tank is not vented to the atmosphere.
On a factory tank, the vent line from the cam chest hooks directly into the tank. On my setup, the vent line from the cam chest hooks directly into the tank.
On a factory setup the vent from the heads blows into the throttle body.
Aftermarket most folks vent to free air,, I vented to an existing "vent" line,, how it works or why it works or hell,, even if it works,, I dunno,, but if it's okay as a vent for the bottom end,, I don't see why it shouldn't work for the top too.
Old 27th April 2013
Looking forward to it. I believe schedule says gates open at 8? As long as my wife isn't having babies I'll be there.
Old 27th April 2013
Ok, here's the deal, If the oil tank is air tight and vents to the cam chest and you run the head vents into that line, where does the blow by air go? It never leaves the inside of the motor until it builds enough pressure to leak past gaskets or maybe the oil tank cap. I might be wrong though.
Old 27th April 2013
JohnK's Avatar
...and what was Harley R&D thinking with the cam chest vent line, when it's not really venting anything?? ?
Old 27th April 2013
JohnK's Avatar
Have fun and good luck tomorrow, be it on the track or the delivery ward!
