0 Not an ironhead, but....
Last Post: Peteroo
Last Post: t120r
0 On starting a new thread
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 Will 04 and later used jugs & pistons fit 01 without major problems?
Last Post: tussuck
Last Post: Skeezix
0 5 gal tank
0 Speed
0 1200 conversion
Last Post: Magneto Sportster
0 opinion time (bike broke again)
Last Post: Skeezix
Last Post: r100steve
0 testing wiring harness connections
0 2011 1200C tuner?
Last Post: tussuck
0 Timing
Last Post: ezmerf
0 Mild 1250 build thoughts?
Old 5th May 2015
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud of
152 miles for me, maybe once I get consistent, unless we have eastcoast drags there.
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 5th May 2015
Xl-1250r's Avatar
Xl-1250r Xl-1250r is offline
Sportster/Buell Model: 883 hugger
Xl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to beholdXl-1250r is a splendid one to behold
I think Lebanon and epping are about the same distance for me I plan on hitting the strip this year.
1995 hugger xl 883>1250 sledge hammer 600 cams HSR45 Sledge air cleaner...
Old 5th May 2015
majam1's Avatar
majam1 majam1 is offline
majam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant futuremajam1 has a brilliant future
Epping is doing a Street Outlaw type deal on Wednseday nights this year like you see on the Discovery Channel. Place will probably be jammed all summer on Wed. night!
Old 10th June 2015
flflash's Avatar
flflash flflash is offline
Sportster/Buell Model: XL1200L Sportster
Sportster/Buell Model #2: XL883L Spt
Sportster/Buell Year #2: 2005
flflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to beholdflflash is a splendid one to behold
Originally Posted by cycowrencher View Post
I do some stop light idiocy pretty regularly, but this year I am planning on taking it to the strip. I'm not going to run the series, just test and tune to get some seat time.
I have all the gear, Snell helmet, armored leather jacket, boots... I know its not running anywhere close to 10.99, so I won't need a lanyard kill or hot pants...
The bike is a 2003 1200
N4 cams
.010 base gaskets
.030 head gaskets
@ 9.4:1 compression
Ultima Ignition curve 4
21 tooth front/ 48 tooth rear ( about 135 in 5th at 7K rpm)
I am hoping to get a baseline dynorun before I get to the track.
I have had pretty good luck with 3500-4500 rpm launches, but I know the tire is slipping on the unprepared asphalt I screw around on. Anyone have a target time I should be shooting for provided I don't miss any shifts and get a good launch.
So have you got out there and ran it yet?
Just a poor old broke mechanic still wanting to Go Fast!
Old 10th June 2015
Unfortunately, no. If I do get to run this year, it looks like it will be at MIR in Budds Creek MD.
[Caution Dirty laundry airing to follow...]
The following is a small excerpt from the hell that has become my life...
My snell helmet was cracked when it fell off the attic floor to the lower floor... ordered a new DR. Sin Scorpion helmet.
My father has Transitional Cell cancer. a week ago we got some really crappy news. The cancer was caught late due to details I won"t go into as I have not decided what to do about it yet... It was caught at stage 3 and he went through Chemo last year. the Chemo reduced the tumor, but it did not prevent it from spreading to his bones, lymphnodes, lungs, and brain. He has leisions on his brain, and many small tumors inside his brain. The current prognosis is 6-10 weeks- 6 months. I have some loose ends to tie up mere in MA for work and such, then I am headed to MD to spend as much time with him as possible when not on travel to stay employed.
Old 10th June 2015
flflash's Avatar
Damn sorry to hear about your Dad we lose way to many friends and loved ones to cancer. Spend as much time as you can with him and take care of his needs. Life sucks at times all we can do is keep beating it down and keep going.
Old 10th June 2015
mac93 mac93 is offline
Sportster/Buell Year: 95
Sorry to hear, sounds like you're doing the right thing. Prayers sent.
Old 10th June 2015
Thank you.
Old 10th June 2015
scottkilowatt scottkilowatt is offline
scottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud ofscottkilowatt has much to be proud of
Amen. Thoughts and best wishes to you and yours cycowrencher.
"I ain't old, just out of date"
BEST ET 11.63 BEST MPH 114.52
Run Your Bike-Not Your Mouth
'The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over.'
Hunter S. Thompson
Old 24th June 2015
I am down at Pops house, and this Friday night we are going to MIR (Budds Creek) street night to get some testing in. I have been playing with the timing curves, and I think its as good as i can get it with out some dyno time. She won't tolerate more than 26* all in by 2800 when she is warm. This also when she pulls the hardest. Limiter is set to 6900 and the light is set to 6200. 9 out of 10 times I can react to the light and just keep it off the limiter. One last hurrah for the old man and a memory I can hold on to.
