0 1966 XLH...sort of
0 Info needed on mini sumps.
0 Brotherhood of the traveling lid
0 VIN Oddity
0 yost power tube guy
Last Post: keys79
0 Cleaning carbon build-up
0 Chinese S&S carbs
0 HF bike lift
0 Gasket kit recommendation?
Last Post: BigMek
0 Sticky Ironhead trans
Last Post: BigLerowski
0 Improving braking 66 XLH RestoMod
0 Piston and cylinder condition
Last Post: Yourstrulythom
0 fork tube cap
0 Bikers choice main jet threads
0 Graduated to Ironhead
0 What oils do you run in your ironhead
Last Post: Almond farmer
0 S&S MGAL carb
Last Post: 11B40
4 The no-debate OIL POLL
0 Don't Think I Ever Did This
0 04 brake upgrade question
Last Post: Calcustom
debster, brknwng (72), TerryW (67), doc_davo (65), clh, Hanoverfiste (48), XL-DecentGlide (45), nobleff517 (45), joekangiser (42), scroggy (36), sgvrider (33)
Jake42 Jake42 is offline
Sportster/Buell Model: 883
Jake42 is an unknown quantity at this point
Default Short Shots w/mid controls
First of all sorry if this is the wrong sub forum, there’s just so many.
I’m looking at grabbing a 2001 883 Sportster in my area. I noticed it has v&h short shot pipes on it but it also has forward controls. I haven’t had much luck looking around but my question is will I be able to switch back to mid controls with the shots on it? It’s not looking too confident but I figured I’d toss this question out to someone who potentially had experience with it.
Thanks guys
I think that’s won’t be an issue, take a gander over on the Vance and Hines web page and it will have the information that you need.
Highly-Dangerous's Avatar
Highly-Dangerous Highly-Dangerous is online now
SPANIARD
Originally Posted by Jake42 View Post
...will I be able to switch back to mid controls with the shots on it?
Yes, but.... check specifically for your year bike.
http://xlforum.net/forums/showthread.php?t=607358
