0 1966 XLH...sort of
0 Info needed on mini sumps.
0 Brotherhood of the traveling lid
0 VIN Oddity
0 yost power tube guy
Last Post: keys79
0 Cleaning carbon build-up
0 Chinese S&S carbs
0 HF bike lift
0 Gasket kit recommendation?
Last Post: BigMek
0 Sticky Ironhead trans
Last Post: BigLerowski
0 Improving braking 66 XLH RestoMod
0 Piston and cylinder condition
Last Post: Yourstrulythom
0 fork tube cap
0 Bikers choice main jet threads
0 Graduated to Ironhead
0 What oils do you run in your ironhead
Last Post: Almond farmer
0 S&S MGAL carb
Last Post: 11B40
4 The no-debate OIL POLL
0 Don't Think I Ever Did This
0 04 brake upgrade question
Last Post: Calcustom
debster, brknwng (72), TerryW (67), doc_davo (65), clh, Hanoverfiste (48), XL-DecentGlide (45), nobleff517 (45), joekangiser (42), scroggy (36), sgvrider (33)
Mike1nw Mike1nw is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Suzook Burgman 400/ 2008
Mike1nw is an unknown quantity at this point
Default A couple more noob questions (Fuel, EFI)
just bought 2007 883, 10,000 miles
changed engine oil
changed tranny oil, with HD synthetic
1. The O.M. sez use 91 octane, is that what y'all use in the 883
2. The 2007 was an early year for F.I. Are there any problems common to 2007 883's
I have a couple hundred miles on this, it's a fun bike so far
shanneba shanneba is offline
changed engine oil
Yes ( I have a 1200)
Yes- there are issues with corrosion on the fuse panel for one.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
BKB's Avatar
BKB BKB is online now
Yes, use 91, all the time when it's available. If you get stuck out in the boonies & can't get 91 or better, it will run on 87 or 89, just don't try to give it full throttle. It'll let you know how much it don't like that.
sportsterdoc's Avatar
Post one
http://xlforum.net/forums/showthread...1983459&page=2
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
]I bought my ‘13 “72” in late ‘16 and it came with a dealer installed brand new EFI Pump. I used Chevron in it and then when Shell took over most of those stations is used their top grade with the N2 cleansing agent.
My EFI line O-rings dried out and failed very quickly with the Shell V-Power gas.
I no longer use it. 😡
