0 Ironhead in the uk
0 More PhotoBucket Horrors...
0 Sportster Cobra seat
Last Post: Magneto Sportster
0 so where the heck is insane shane?
3 Shaky Dave Recovery
0 Rain pants
0 Brake line to short
0 Sleeve cylinders?
Last Post: Hopalong48
0 Sportster kick stand
Last Post: ldurmon
0 cam lobes
0 Glyptal?
0 TC88A update ?
0 1969 Sportster 50th Anniversary T-Shirts
0 lengthen master cylinder
Last Post: 11alan111
0 Mid West Meet & Greet
Steph (54), yubman (49), Windesch (47), Mark_Bench (43), motherduce (41), sgtfry (38)
  #31
Old 8th December 2019
Nibelungen's Avatar
saying that for peace of mind i will buy the FAG7200B...
i have done some search on sites for mechs engineers
maybe i'm wrong... but it seems to me that the type of bearing that Mo.Co use on Sporties is an deep grove radial ball bearing... and it seems it can take (and is designed for) either radial, than axial loads...
emancipate yourselves from mental slavery, none but ourselves can free our minds
i have done some search on sites for mechs engineers...
No shortage of idiots that are also mechs engineers...
If you get a 7200B compare it to the bearing you take out. Make sure you install it correctly. It's directional in regards to thrust.
If you think the original bearing is good enough just leave it there.
Nibelungen's Avatar
of course
axial load outward (as to say to my face)
FAG or SKF is the same isn'it?
as for comparing the two breed...
yes.. i have seen the tech draws of both
Old 9th December 2019
If they're both 7200B they're both axial thrust if that's what you're asking.
I bought FAG because I found a really good deal on bearings that were NOS.
I would have bought FAG or SKF.
wrkdWS6's Avatar
wrkdWS6 wrkdWS6 is offline
Sportster/Buell Model #2: XLH1000
Sportster/Buell Year #2: 1979
wrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant futurewrkdWS6 has a brilliant future
Just a heads up for future bearing purchasers. I purchased a FAG 7200B off Amazon last week, the exact same one that is linked earlier on in this thread. Fake bearings are unfortunately very common so I was nervous buying it from a non authorized dealer but fortunately the one I received it ended up being legitimate. Bearing companies now put a QR code on all bearing packages. You can download the free World Bearing Association (WBA) app on your phone where you scan the QR code and it will tell you if the bearing is authentic or not. Something worth doing to ensure you aren't putting a fake POS in there that could cause you problems down the line.
https://www.stopfakebearings.com/
'06 1200C & '79 XLH
THEWILDONE THEWILDONE is offline
Sportster/Buell Model: 1200 XLC
THEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud ofTHEWILDONE has much to be proud of
Truer words are seldom spoken Tom!!!!!
Cool, thanks for sharing that.
