0 supply and demand
Last Post: simonster123
6 SPORTY BOBBER PICTURES
0 Oil leak from engine bolt?
Last Post: 1Scooter
0 Which Brake Setup To Use?
0 Speedo cable hunt
Last Post: fafcpa
0 Ran out of gas.
Last Post: Dusz
Last Post: Dusz
0 Сar depreciation
Last Post: Fivecats
Last Post: Kingrabbit
Last Post: bplinson
Last Post: bplinson
0 Ebay vlovkling International bidding ?
0 73 XLCH help
Last Post: Doc308
0 New to Buell S2T
8 Barnett clutch plates
Last Post: BrianS
Last Post: Lone Rider
longrun-pa (73), goose59 (64), Stumble (59), Rowdy65 (58), peten (57), roderash (56), flightmedic (54), sportster steve (53), buscuit88 (35)
eyebrow, headlamp
Old 3rd June 2023
Todd007 Todd007 is offline
Sportster/Buell Year: 1973
Sportster/Buell Model #2: XLCH in pieces.
Sportster/Buell Year #2: 1970
Todd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to beholdTodd007 is a splendid one to behold
Default Tool/trick for headlamp nut removal?
Is the trick to use a thin walled socket or grind down a donor? I can’t get anything onto the headlamp nut in order to separate it from the eyebrow. 3/4” nut, yes? Thanks.
Old 3rd June 2023
JB in NC JB in NC is offline
Sportster/Buell Year #2: 1993
Other Motorcycle Model: H-D FLH
Other Motorcycle Year: 1980
JB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond repute
Reg'lar ol' 3/4 deep socket should do it.
Jim
Old 4th June 2023
ZTatZAU's Avatar
ZTatZAU ZTatZAU is offline
Other Motorcycle Model: '89 GL1500 & '71 CB750
Other Motorcycle Year: ^^^^
ZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond reputeZTatZAU has a reputation beyond repute
Jim
A regular 3/4" deep well socket should do it... unless the stud and nut are slid all the way to the end of the adjusting slot. This places the nut up against the inside of the eyebrow barrel... leaving no room for the wall of the socket.
My 73 XLH suffers the opposite problem... that is, I cannot aim my headlight down as far as I'd like it because... you can't tighten the nut with a 3/4" deep well socket without pushing the nut back away from the barrel wall... which raises the headlight beam.
So, I'll be watching for a solution to Todd's problem; as it will likely solve mine!
ZT (Ironhead Apprentice)
Old 4th June 2023
Ground down a socket. But 13/16 not 3/4. Off it came. T. Thanks. All.
Old 4th June 2023
There's your problem: it's got the wrong nut on it.
Jim
Old 4th June 2023
Racepres Racepres is offline
Sportster/Buell Model #2: XLH 883 STD
Sportster/Buell Year #2: 1995
Racepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud of
Jim
Absolutely...All were 3/4 from MoCo....
