0 supply and demand
6 SPORTY BOBBER PICTURES
0 Oil leak from engine bolt?
Last Post: 1Scooter
0 Which Brake Setup To Use?
0 Speedo cable hunt
Last Post: fafcpa
0 Ran out of gas.
Last Post: Dusz
Last Post: Dusz
0 Сar depreciation
Last Post: Fivecats
Last Post: Kingrabbit
Last Post: bplinson
Last Post: bplinson
0 Ebay vlovkling International bidding ?
0 73 XLCH help
Last Post: Doc308
0 New to Buell S2T
8 Barnett clutch plates
Last Post: BrianS
Last Post: Lone Rider
longrun-pa (73), goose59 (64), Stumble (59), Rowdy65 (58), peten (57), roderash (56), flightmedic (54), sportster steve (53), buscuit88 (35)
Old 15th June 2022
rellquist rellquist is offline
Sportster/Buell Model: Hugger
Sportster/Buell Year: 1989
rellquist is an unknown quantity at this point
Default Tach Swings Wildly
I have an FL style dashboard and tank conversion on my 89 883 Sportster. The speedo has a tach built in. The tach needle jumps around wildly. I put a resistor in line with it but that didn't help. The wires going to the coil and the tach are tight and no corrosion. Can a coil that works fine to run the engine cause this problem or is it just the tach? Anybody have this problem with this style of speedo? The speedo says Harley Davidson on it so I believe this conversion was a Harley kit back in the day.
Old 15th June 2022
decman decman is offline
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Check the ground on the tach.
Old 15th June 2022
rejeanprimeau's Avatar
Check the battery terminals after checking the others gizmos.
Old 16th June 2022
Are you running the original Ignition Module?
Or what aftermarket module are you running?
Single-Fire ignition setup or dual-fire setup?
Pre-2004 Sportster tachs were intended for dual-fire ignition
with the uneven firing.
2004-later, Sportsters went to a single-fire ignition configuration
and the tachs used the digital data bus information.
On the BigTwins, this difference happened in earlier years.
You might need to pin down the Tach model to know what it expects.
For Sportster Tech Info:
Old 19th June 2022
+1 mr. relax
the resistor is not the way to go. IF you are picking up rf interference by the wires running to close to the high tension leads, first try a diff route. you can also try a filter capacitor to shunt the rf to ground.
Old 21st August 2022
Hellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant future
My battery cable came loose and did some weird re-booting type things like that.
Well, the speedo froze at 40MPH so I got a Drag Specialties unit that looks just like the HD one that froze. That cured the tach problem but at 1200 miles on the new speedo, it went up to 60MPH while I was doing 50 and froze there. I got a replacement Drag Specialties and on my first ride I was doing 55 MPH and the speedo started climbing all on its own. It went all the way around to 6 o'clock where it hit the tach needle and stopped. It stayed there even after I stopped the bike. This is a mechanical speedo with a cable. Anybody experienced this? Is the Drag Specialties unit just a POS?
I don't know what DS speedo/tach you bought, but I'd be checking the wiring & power to the unit. Even though the unit takes a mechanical drive, it may operate electrically (as does the tach)...
I would check voltage levels to the unit. And make sure you have a good ground on it.
On the other hand, maybe you're right about poor quality...
