0 Opinions on Mallory unilite ignition
Last Post: mrmom9r
0 1968 ex barn dweller thread
Last Post: mrmom9r
0 Li/Ion battery in '03
0 Tools
Last Post: denguy
0 Installing jugs finally but another Q
0 18” rear wheel mag
Last Post: Yourstrulythom
0 Microsquirt?
Last Post: Curbside
Last Post: gusm2
0 Arlen Ness F-Bomb Pipe Test
0 fork oil change with Ricor intiminators
0 Brake light issues
Last Post: night-train
0 Microsquirt EFI Conversion
Last Post: Randy_rots
0 Sifton cams on stock 74 XLCH
Last Post: lajam175
0 -65A mufflers
Last Post: DR DICK
0 Chasing a generator noise
Last Post: DR DICK
0 55* this morning
0 2007 883R From Sunny Old England!
0 Pinion shaft holder tool
0 Better Brakes
0 Do you like Mexican food?
lineberger, 39dan (62), FstPig (61), jmdajd (57), ironhead 74 (57), erjasn84, Bada Bing (56), ottchuck (55), OutlawTexan67 (53), RAJ (47), Wintersdark (44), robychopper (44), TnsporT (43), MotoSquirrel (36)
Old 10th October 2020
Mike1nw Mike1nw is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Suzook Burgman 400/ 2008
Mike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud ofMike1nw has much to be proud of
Default Replace sprocket
2007 883
Now is a good time to change sprocket
Present one is 28 teeth
I'm thinking maybe 30 t front and use same stock rear one?
That would cut highway RPM by 1/15.
Sportster/Buell Year #2: 2005
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
Do you have to buy a Longer belt when changing sprocket to bigger size??
Folkie Folkie is offline
Bikes that come stock with a 28T tranny sprocket have the 136T belt; those with 29T and 30T tranny sprockets have the 137T belt.
Which is not to say that you can't make do with the shorter belt. Some, apparently, have managed to do so.
Old 11th October 2020
Offhand, if you add 2 teeth to the small sprocket, the belt "sees" only 1 extra tooth, on the sprocket, so I'm thinking the axle adjusters should be able to compensate for that. There seems to be room to move the axle that much.
rocketmangb's Avatar
I went from a 29 to a 28 and used the stock belt
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 15th October 2020
Sirrom1's Avatar
Sirrom1 Sirrom1 is offline
XL Forum Bronze Supporting Vendor
Sportster/Buell Model: 883L
Other Motorcycle Model: Bonneville
Other Motorcycle Year: 1967
Sirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud of
Default Belt Vs front pulley size
You can use up to 28, 29, 30, 31, or 32 tooth front pulley with the original belt, 136 or 137 tooth.
The 32T/136T uses all of the forward adjustment, but you can still properly adjust deflection.
The 32T front gives you almost the same final drive ratio as a 1200.
...I can't be outta gas,
I haven't turned around yet...
There's also a 139T 1" belt that's OE on Buells.
Old 19th October 2020
I've found several 30 or 31 or 32 t sprockets. All seem to be aluminum, where the stock one is steel..... Kind of nervous about replacing with Aluminum sprocket?
kitabel kitabel is offline
Sportster/Buell Year: 1989
Going up from 28 > 30 also reduces torque in every gear by 6.7% (but it only matters in 1st gear and high gear).
Makes your 883 feel like 824cc.
Old 25th October 2020
Sirrom1's Avatar
Default Front Pulley Life
You can find 30, 31, & 32 tooth front pulleys in non-aluminum.
My personnal experience and confirmed in this Forum shows Aluminum pulleys that are 100%, the center splines fail about 10,000 miles. The aluminum pulleys with steel center, the belt teeth fail at at about 15,000.
Cast and steel pulleys can last over 100,000 miles.
