0 1968 ex barn dweller thread
0 Li/Ion battery in '03
0 Opinions on Mallory unilite ignition
Last Post: Heff
0 Tools
Last Post: denguy
0 Installing jugs finally but another Q
0 18” rear wheel mag
Last Post: Yourstrulythom
0 Microsquirt?
Last Post: Curbside
Last Post: gusm2
0 Arlen Ness F-Bomb Pipe Test
0 fork oil change with Ricor intiminators
0 Brake light issues
Last Post: night-train
0 Microsquirt EFI Conversion
Last Post: Randy_rots
0 Sifton cams on stock 74 XLCH
Last Post: lajam175
0 -65A mufflers
Last Post: DR DICK
0 Chasing a generator noise
Last Post: DR DICK
0 55* this morning
0 2007 883R From Sunny Old England!
0 Pinion shaft holder tool
0 Better Brakes
0 Do you like Mexican food?
lineberger, 39dan (62), FstPig (61), jmdajd (57), ironhead 74 (57), erjasn84, Bada Bing (56), ottchuck (55), OutlawTexan67 (53), RAJ (47), Wintersdark (44), robychopper (44), TnsporT (43), MotoSquirrel (36)
Old 25th October 2020
piratemike piratemike is offline
piratemike has disabled reputation
Default Speedometer and Mileage
On a 1996, 1200 Sportster, where is the vehicle mileage stored? In the Speedo or a computer somewhere else? If a speedo gets replace how is the mileage transferred over to the new speedo?
Thanks
Folkie Folkie is online now
I expect it's the same as on the early rubbermounts; ie: the mileage is stored in the speedo. When getting a new speedo you have to say what the mileage should be set to, and H-D supply the speedo with that mileage already set on it.
Folkie's right - It's stored in the Speedo - Until 2004 (or 98-03 Sport) there was no engine or system control module that communicated with the speedo - Only the VSS, directly to the speedo. There was only the cancel signal line from the speedo to the turn signal canceller.
2004 started communications over the Serial Data Bus (SDB)
2014 started communications over the CANbus
And even though there was on the carby rubbermounts, the mileage was still stored in the speedo, not the ICM.
