Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 Massachusetts 2022
0 1977 Sportser - Finally running, but couple issues
Last Post: ironbar
0 Before and After pictures/Videos of your bike (All Welcome)
Last Post: Ghostdog
Last Post: slowcycle
0 33.4mm fork bushings
Last Post: Staffords
0 My XLCH/XLR Hybrid build
Last Post: davixlrtt
0 A Reliable Engine
Last Post: Ghostdog
0 72 ih stroker advise needed
3 Rear galiper bracket spec.
Last Post: DG Racing
0 On board voltmeter
Last Post: Len PA
0 Secondary Pulley Sprocket Quality
0 Oil Soaked Air Filters
0 Ugly Duckling
Last Post: DR DICK
0 extortion
0 incredible complainers
0 Regulator test 1974 xl
0 rotor
Last Post: DR DICK
0 Aftermarket Ironhead Seats - ID?
Last Post: DR DICK
0 New to me '74 xlch
5 Frankenstein forks- preload?
Last Post: WVDevil
IronHead83, AMATRAVELER (60), ZYBAN (58), tom_ski (57), mid30 (56), im_justin_sane (54), DOZER (52), acman145acp (52), espacef1fan (37), fernandopn (37)
Old 12th November 2018
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
Default How many amps does a 2003 XB charging system create?
Hey guys a question if anyone here knows.. I have a 2003 XB Buell stator and and regulator on my custom build. Does anyone know how many Amps the charging system is rated at.. I think its 32 or 38 amps?
The main breaker on my aftermarket wiring loom is 30 Amps.. is this going to be a problem?
Thanks
I found this online for a 2003 XB9.. Im seeing 34-38 amps charging, and the battery breaker on the XB9 is rated at 30 amps so Im seeing that Im good to go..?
Old 13th November 2018
Air-Cooled Forever
You should be good to go.
Here's the Sportsterpedia section on the Charging System:
http://sportsterpedia.com/doku.php/t...harging_system
IXL _______ >>>> My Motorcyle Chronicles Are Here<<<<
Check Out The Sportsterpedia
