0 Anyone still use Cycle Shack duels?
0 1979 oil routing diagram
Last Post: Jorgem79
0 '03 883 Hugger Odd Clutch feel, 1st gear jumps out
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Last Post: barefoot
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
Old 28th April 2009
Sanch Sanch is offline
Sportster/Buell Year: 1973
Sanch has disabled reputation
Default LED Blinkers in rear only
I've been reading posts here about replacing regular bulb blinkers with LED blinkers and there's been mention of needing a load equilizer. My bike never had blinkers and I only want to put ones on the back. Does this create a problem, do I need two load equilizers since I will only have one blinker on each side? Also, reading about all this I decided it would be a good idea to replace the headlight with an H4 halogen bulb. Do they make a conversion for this as I'd like to keep the stock headlight.
Thanks,
Sanch
Old 28th April 2009
Icefire's Avatar
Icefire Icefire is offline
Icefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura about
Default ive got em without equalizers...
I have a LED taillight/brake light assembly, works fine with no equalizer, and Ive been running a PIAA H4 headlight bulb for years without any mods....I think you only need to equalize the load if you want something to blink...
Keith Black .010 over pistons, Andrews PB+ cams, Accel Supercoil, solid core wires, rejetted Keihin Butterfly carb, S&S air cleaner, Unleaded conversion, valve job, heads bored, new rocker arms, rockers, pushrods, seals, Accel Cyclelite Platinum plugs, Accel 8.8 mm plug wires, Big Boar BB1000 battery, O-ring chain, upgraded handlebar controls,Maxxis tires, GMA front brake, drilled disk, Mustang seat, custom grips, Skull point cover, skull gas cap, RunRoader exhaust pipes, pullback drag bars, etc…
Old 29th April 2009
goldsport's Avatar
goldsport goldsport is offline
Sportster/Buell Model: 1200xlc
Sportster/Buell Model #2: 883 xlc
Sportster/Buell Year #2: 2002
Other Motorcycle Model: yamaha/honda/kawi/bultaco
goldsport is on a distinguished roadgoldsport is on a distinguished roadgoldsport is on a distinguished road
Thanks,
Sanch
I'm not an expert but i swapped out my stock signals for leds in the rear and aftermarkets in the front. (01 1200xlc) I did have to put on a load equalizer in order for them to blink. I believe it depends on the year/make/model of your bike. How I understand it is the signal canceller on new bikes does not "read" the signal to blink and neads to draw more power in order to function proprerly. My turn signals came on but did not blink. They are simple to install. ONE WORD OF CAUTION: If you use the older badlanders o1 model it uses a ceramic element and will generate heat IF YOU LEAVE THE BLINKERS/flashers on for extended period of time. I found out the hard way in the middle of a parade I had my flashers on and a guy tapped me on the shoulder and said "Hey dude your bikes on fire" OH
S--T, smoke was pouring out from under the seat. Turns out the equializers was very hot and melting. After some research I find that they have new models that are "solid state" and will not generate heat. I don't want to find out. Anyway, check out "badlanders" web site they have a lot of good info on this. I don't have the link or I would give it to you. Hope this helps!! Good luck! P.s. you can find them on Ebay for around 25 bucks.
I understand why a dog sticks his head out the window!
Old 29th April 2009
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
You do not need a load equalizer on an IronHead. You need them on modern bikes that have a computer to control the bilnking. That little flasher unit that we have [mine is in the headlite bucket] works excellent on its own.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 29th April 2009
goldsport's Avatar
I believe he's absolutly correct!! Just install and see what happens. Should be fine on an ironhead.
Old 29th April 2009
xl1200r's Avatar
xl1200r xl1200r is offline
Sportster/Buell Model: Buell 1125CR
Sportster/Buell Year #2: 1964
Other Motorcycle Model: Kawasaki Ninja 250
xl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura about
Not sure if this is true.
Even modern bike use a mechanical flasher (my '07 Buell did), and when I installed LED blinkers there wasn't enough load on the box to make them blink - they just buzzed and looked half-lit.
I was able to find another flasher box that plugged in but was designed to run on less draw, and while the lights blinked faster than stock, they at least blinked.
If you can't get another box to handle the lower draw, you'll need load equalizers to increase the resistance going to the flasher unit. Otherwise, they won't flash.
And LED brake/tail/turn assembly likely has all the electronic goodies built into it.
Old 30th April 2009
IronMick's Avatar
It is true as far as IronHeads are concerned. You do not need a load equalizer in an IronHead. There is no flasher box that plugs in. There are different flashers available in the auto stores and WalMart etc. Some are labelled as Heavy Duty. These are the wrong ones for an IronHead application. Just the simple inexpensive flasher is what is needed.
Old 29th April 2009
77ridgidframe's Avatar
77ridgidframe 77ridgidframe is offline
Sportster/Buell Year: 77
77ridgidframe is an unknown quantity at this point
yea i have led's on the front of mine in the mirrors.....i only have them as markers not blinkers(blinkers dont exist on my bike) i did have some on the back too for about 20 miles after a day of installing them ,,,,damn bike just rattled them right off....so i took it as she just didnt want them there lol.....but i have had no electrical probloms because of them no
Old 29th April 2009
cbear cbear is offline
Sportster/Buell Model: XLH-883
cbear will become famous soon enoughcbear will become famous soon enoughcbear will become famous soon enoughcbear will become famous soon enoughcbear will become famous soon enoughcbear will become famous soon enoughcbear will become famous soon enough
If an iron uses a flasher relay like old cars, then you can get an electronic flasher that isn't load dependent. I'd only do that if you do run in to issues.
Old 29th April 2009
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to all
Yeh, it does. and the cheap car flashers from car parts stores work just as good as the oem harly parts - just get the same number of pins (2 or 3, i forget which) and plug it in.
