0 Anyone still use Cycle Shack duels?
0 1979 oil routing diagram
Last Post: Jorgem79
0 '03 883 Hugger Odd Clutch feel, 1st gear jumps out
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Last Post: barefoot
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
Old 29th April 2009
supr2nr's Avatar
supr2nr supr2nr is offline
Sportster/Buell Year: 1976
supr2nr is on a distinguished roadsupr2nr is on a distinguished road
Default Generator
Looking down at the generator from the top which arm is the Field and which is the Armature?
If I'm not mistaken the left would be Armature and the right would be Field correct?
- Randy
Old 29th April 2009
FourCams's Avatar
FourCams FourCams is offline
Sportster/Buell Year: 1969
Sportster/Buell Year #2: 1972
Other Motorcycle Model: FXSTC
Other Motorcycle Year: 1996
FourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really nice
Look really closely on the generator housing. The "A" and "F" should be stamped near the terminals.
Usually the A is on the left but there's no guarantee. Some are different. If you can't find the stampings you can tell by looking at the brush leads. The one that's riveted to the brush plate goes to the "F" terminal.
♠ 1969 XLCH ♠ 1972 XLCH ♠ 1996 FXSTC ♠
Old 30th April 2009
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
Most have the A being closer to the front. I have actually seen one that is opposite. It is an older one. Did not know it was different until it would not work; opened it up and said "this is wired wrong"; then realized it was opposite.
Scrape off some paint and look closely for the indented letters in the metal case.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
