0 Putting a 4.5 tank on my Roadster, but I still want it to look like a Roadster.
Last Post: gravydog
0 Small B and S stickers?
Last Post: Loony
0 Oil leak after assembly ?
Last Post: hexnut
0 Any K model guys interested in cam regrinding?
Last Post: trappnman
0 Security system
5 RF turn signal flashing way too fast...
Last Post: stray
Last Post: tigger
0 carb pop on acceleration from stop
Last Post: Bone
Last Post: Reverend G
Last Post: GeoK
0 '75 Starter clamp
Last Post: zipdog
0 First Harley
Last Post: Kaptain
0 Axtell iron 1250 bored to 1275
0 1200 C Pics!!!!
0 Front brake combination not working well. Suggestions?
0 Crashed my sporty today :(
Last Post: Centennial Sportster
0 Spokes or Mags
7 *Help* HD quick-release brackets with other windshields??
Last Post: Bone
3 Wtb, Wts, Wtt, Wtg (Rubber Mounts)
Last Post: wongjohnson
0 THE Trainspotting Thread
3 WTB: Loconia handlebar set for a '65 CH
Last Post: KCinSB
0 Prevent tappet cover flooding
Last Post: RKN
0 "I just needed to get this out of my garage."
0 The forum got talent
0 Hampshire Downs And Dorset Drovers
0 New Guy's '76 Ironhead Build/Chop
breilly888 (66), txsporty (62), michtif (53), Rabs (45)
Old 18th November 2009
scottericsonon scottericsonon is offline
Sportster/Buell Year: 1965
scottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enough
yes i found it mick........
if you look it's on the 12V side prior to BOTH genny AND oil press idiot lights......
i tweaked my drawing to incorporate this and will replace the original with it.......
thanks for the help
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Here's one:
thanx bob......
ive seen that one before but i wanted to draw something up that was color-coded and showed the couple idiot lights that i like to run
as well as designing the headlight switch so that my low beam is on when i turn on the brights to get the maximum amount of headlight
Old 21st July 2010
ekoog82's Avatar
ekoog82 ekoog82 is offline
Sportster/Buell Model: 85 XLH 1000
ekoog82 is an unknown quantity at this point
Originally Posted by scottericsonon View Post
well one of the things i'm planning to do to my bike this year is re-wire it...........
theres a couple burned spots in my harness and some P.O repairs that aren't real pretty....
plus i want to clean up that rats nest inside the headlight
so i drew up this little diagram that someone else may also find useful........
i plan to print it out and keep it inside a ziplock baggie in my tool kit "just in case"
Are you running signals on this setup?
Old 14th August 2010
Chili Palmer Chili Palmer is offline
Sportster/Buell Year: 1976
Chili Palmer is an unknown quantity at this point
I'm not sure about HD's (I'm very new to them) but on older cars that diode is there to allow the alternator to be excited, even if the light is out.
When you turn on the ignition it powers the light which is then grounded through the alternator and the light comes on, when the car is started and the alternator provides power it pushes 12v back at the light and the two 12v leads feed into the light from both sides and the light goes off. The diode is there to make sure the alternator is excited even if the alternator light goes out. The diode, on a car anyways, is wired in between the two terminals on the light.
Additionally - In theory you can run a light only (which is how I built my Jeep) or a diode only.
boilermaker's Avatar
boilermaker boilermaker is offline
Sportster/Buell Model: 81 sporty
boilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really nice
Yup only diff is the old ironheads use Generators but your explanation is right
generators dont charge at an Idle so this is why your light is on at an Idle and goes out once you pick the Idle up and it starts charging
sesenta y ocho
doodah man's Avatar
Default re-what? re-wire!
scott, once again thanks for all yer help previously - that wiring diagram fixed me up just right and i've had zero problems from my electrics since my rewire! you rock!!!
caution! do not stop on tracks.
Old 10th March 2011
UncleJess48 UncleJess48 is offline
Sportster/Buell Year: 1979
UncleJess48 is an unknown quantity at this point
Default Diode Question
How do I make sure the diode is in the proper direction? I have done some wiring before but have never had to mess with adding a diode.
Old 10th March 2011
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
The band on the diode is on the generator side (away from the light)
24 beers in a carton. ...24 hours in a day . .. coincidence??
Old 12th March 2011
xlhiron's Avatar
xlhiron xlhiron is offline
xlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enough
You're showing the dioide to the gen light in your drawn diagram.
Catching a yellow-jacket in your shirt at seventy mph can double your vocabulary.
