0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
Old 14th June 2013
the1337aaron the1337aaron is offline
Sportster/Buell Year: 1973
the1337aaron is on a distinguished roadthe1337aaron is on a distinguished roadthe1337aaron is on a distinguished road
[/QUOTE]
can anyone label the breakers in this drawing and should there be a fuse in between the battery and regulator or between battery and ignition??
Old 14th June 2013
Pan55's Avatar
Pan55 Pan55 is offline
Sportster/Buell Year: 77
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 77
Other Motorcycle Model: 1978 FX Shovelhead
Pan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to behold
to answer your questions,,,
personally,
I run a fuse between my regulator and battery, ( to me..this one is manditory)and also I run one * just in case* between my battery and switch.....not needed here, but ya never know if a wire will chafe/ground out....juts some added peice of mind
Old 14th June 2013
ok and what size fuse did you run between batt and reg?
Old 14th June 2013
also can you tell me the breakers also, I think I have them figured out I just want to make sure.
Old 14th June 2013
runingmouse's Avatar
runingmouse runingmouse is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Sprint ss
Other Motorcycle Year: 1967
runingmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura about
Besides the light,accessory,igniton breakers. Between battery and switch 30 amp. breaker or fuse.
Old 15th June 2013
Ol Rip Ol Rip is offline
Sportster/Buell Year: 95
Ol Rip has disabled reputation
Look, I'm no electrition by a long shot, but don't you have TWO hot wires running to the tail light and no ground.
Old 15th June 2013
One hot for the tail light, another for the brake light. Tail light assembly is grounded to the frame via the fender and fender struts so no ground wire needed.
Old 15th June 2013
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
The 30 amp breaker or fuse should be connected right to the + battery terminal.
Then the wires from both the regulator and ignitions switch connect to the other side of the breaker or fuse.
That way the only unprotected wire on the bike is the two-inch length from the + terminal to the fuse or breaker. Make sure it is clear of the battery box lid etc.
