0 Forum member mug shots
0 Struggling with year??
Last Post: Sugarsinner
0 Dynatek Ignition questions
5 1969 XLCH exhaust question
Last Post: Coz
0 I'm back...
Last Post: screndname
0 Generator removal
Last Post: RDHenley
0 Random video thread.
5 RSD LED Indicator
Last Post: mk87ita
Last Post: RDHenley
Last Post: RDHenley
0 A Day in the Life...
Last Post: RDHenley
0 What engine oil do you use?
0 did the quiet baffle install short shots
Last Post: b0fh
0 Do people notice your bike?
0 1983 XLX--Back at it
Last Post: 83XLXCT
0 compression low?
0 can you tell me why?
0 Mid or forward controls.
Last Post: Bigshankhank
Last Post: unleashed
0 93 Sporty Key replacement
0 4 Speed Stator Replace
0 Spokes or Mags
Old 4th April 2020
rickie1031's Avatar
rickie1031 rickie1031 is offline
rickie1031 is on a distinguished roadrickie1031 is on a distinguished roadrickie1031 is on a distinguished road
Default 2007 XL1200L Rocker Box Gasket Replacement-Moving the ignition wire harness
Hello,
I am looking to replace the rocker box gaskets in my 2007 xl1200l but, I am having issues removing the wire harness attached to the frame in order to pull the top of the box off the bike. Every video I have seen of the gasket replacement, there is no harness blocking the top box. See photo....
Any help would be appreciated. Thanks in advance.
R
Old 4th April 2020
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud of
That harness snaps into the right side of the bracket that is welded to the frame. First, you have to remove the Torx bit screw from the left side of the cover and then move to the right side of the bike and pull hard and straight out on the harness and plastic cover to release it from the bracket.
Old 4th April 2020
rickie1031's Avatar
Default Thank you
Thank you for this. I can't believe I missed the tori screw on the left side of the bike. It did take a bit to move th cables and ignition but am now able to easily access the rocker box. Thanks,
R
Old 4th April 2020
NP, that’s what this forum is for.
