0 Dynatek Ignition questions
5 1969 XLCH exhaust question
Last Post: Coz
0 Struggling with year??
Last Post: ohiodk
0 I'm back...
Last Post: screndname
0 Generator removal
Last Post: RDHenley
0 Random video thread.
5 RSD LED Indicator
Last Post: mk87ita
0 Forum member mug shots
Last Post: RDHenley
Last Post: RDHenley
Last Post: RDHenley
0 A Day in the Life...
Last Post: RDHenley
0 What engine oil do you use?
0 did the quiet baffle install short shots
Last Post: b0fh
0 Do people notice your bike?
0 1983 XLX--Back at it
Last Post: 83XLXCT
0 compression low?
0 can you tell me why?
0 Mid or forward controls.
Last Post: Bigshankhank
Last Post: unleashed
0 93 Sporty Key replacement
0 4 Speed Stator Replace
0 Spokes or Mags
  #121
Old 15th April 2020
Sportster/Buell Year: 1969
RicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to behold
Originally Posted by mikethebike61 View Post
100% correct.....but what some do not realize is the cold flow that you should be concerned with is how fast the oil returns....a positive displacement pump will move the oil.....or break if hydraulic lock happens....but if you go out at 35 degrees and fire up the beast with 70 wt and rev it to 6500 rpm the oil might not make it back without the pump going dry....the high rpm BMW cars will not allow the engine to rev past a predetermined rpm until the oil temp is up.
I'm in south central Texas when the temps drop into the 50's I'm done riding. LOL
No, seriously 70 is for high temperatures. 50 is for that cold weather shit.
Old 15th April 2020
Originally Posted by Steve9 View Post
Klotz has 70wt
Catchy name!
OUCH that KLOTZ is pricey. If I were to run that I'm afraid I would cut back on my oil change frequency. I don't run an oil filter so I change oil frequently. Maybe installing a filter and going to KLOTZ 70 would work out cheaper in the long run. Something to look into.
