0 yost power tube guy
Last Post: BestCoastXL
0 Oil pressure stays up 20min after shut of
0 Pinion and sprocket side bearing questions
0 Iron 1966 XLRTT
0 Bolts and Metal Type
Last Post: ericfreeman
0 883 rev range
0 Sidehack for XLS
0 S&S Super E
0 trans corner reinforcement 54-72
Last Post: Marsikus
0 passenger with driver's backrest
Last Post: Veeflys
0 Chain drive vss
0 oil filter stuck
Last Post: Bikeaholic
0 New Lifters with new cams with your conversion?
Last Post: yelladox
Last Post: TPEHAK
0 Ia 83 xlx
0 is a buell a harley
0 Hawkeye's 1275 Hammer Performance Conversion
Last Post: hexnut
0 how to reduce buffering
Last Post: Stude
0 Proper XLCH
Last Post: revjen45
0 73 xlch gas flowing from carb
Old 6th March 2021
yashko51 yashko51 is offline
Sportster/Buell Model: xl1200
yashko51 is an unknown quantity at this point
Default 04 883
I found a low mileage 2004 XL883 that I am interested in but the vehicle has an engine that has black painted crankcases.
I do not recall black crankcases being available in 2004.
Am I missing something?
The owner says the frame and engine numbers match.
Thanks
Don
Old 6th March 2021
ZCarFan ZCarFan is offline
ZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond reputeZCarFan has a reputation beyond repute
Is it a XL883R? Dual discs up front?
Old 6th March 2021
rejeanprimeau's Avatar
rejeanprimeau rejeanprimeau is online now
The best there is, you will also get Andrew gears in it.
Just beware of high lift cams.
Old 8th March 2021
Default Nope
The vehicle is not an 883R. It has a single disc front end, standard single speedo, bars with black painted fenders, etc.
All the info I have on a standard 883 says it never came with black crankcases.
Old 8th March 2021
Brad's Avatar
Brad Brad is offline
Sportster/Buell Model #2: 883C/883R/1200C-all sold
Sportster/Buell Year #2: many
Any chance you have the VIN? Did you ask the seller about the black cases?
1995 XL 883 - Phoenix, AZ
Old 8th March 2021
Default Vin
When I asked the owner about the black crankcases, he started to get defensive and said he bought the bike this way. And when I mentioned that 04 883's didn't come with black cases he called me a "hater" and the conversation ended.
He did not supply the VIN
The bike only has 2,700 miles and looks to be in excellent condition but the "red flags" have pretty much put an end to purchasing this. I only ask here about the bike so I am more informed about 2004 Sportsters with black crankcases.
Old 8th March 2021
Sportster/Buell Model: XLH 883/1250
Sportster/Buell Year: 1991
He called you a "hater?" WTF?
I'd tell him to piss off. Buy a rigid mount instead, 1991-2003. Much better bikes than the bloated rubber mounted sissy bikes.
John
Old 8th March 2021
At least “hater” would be non gender specific......never mind.
I.B.A.#26543,
Old 8th March 2021
Sounds like a weird reaction and agree to the red flags part. If you get bad vibes from a seller probably better to move on. There's plenty to choose from particularly if you are patient.
