Last Post: Jollly Rogers
Last Post: mrmom9r
0 Hello from 1970s Wisconsin!
0 mode of failure
0 Moto Guzzi V9 Bobber debut
Last Post: Bone
0 Best Tires to get 2017
Last Post: Four Speed
0 Replacement Fuel line?
0 Shotgun Porn
0 What do you think the wet weight of the Pan America will be?
Last Post: jammantoo
0 Cylinders and static compression checked. Advise?
Last Post: jordan1200
0 Cobra RPT Intake
Last Post: FearTheBeard
0 Dead battery cells - 1997 sportster 883
Last Post: jharback
Last Post: Vohnsen
Last Post: SoonerSport
0 Gravydog crashed again.
Last Post: ed_in_az
Last Post: salveson
0 getting this 78 back to the way it should be.
Last Post: DirtyCory
0 TC88A makes me smile until WOT
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: rj2
0 fat man on a sportster
0 Fitting 2003 sportster seat to 2004 sportster
Last Post: MudDigger
Last Post: SteveK
ziggyhd1 (60), greven (58), bliynd (33)
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1966 Honda Dream 160
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
electronic speedometer seems to be the simplest solution.i'm tempted to go that way myself.bicycle shops sell them.
That's what I'm saying. I can't see the logic in re-engineering the thing and running a cable along the side of the bike to rig up a speedometer that won't be accurate due to wheel size.
Gold Member's Avatar
Sportster/Buell Year: 1972
Electronics are out, too modern, they just don't go with a Sportster, and besides I'm an analog/mechanical kind of guy. There's radar things beside the road all over the place now, I'll adjust the indicated speed with the real speed in my head.
doodah man's Avatar
that speedo cable is available in bulk or longer lengths and can be made to run under the frame and up to the stock location. if i had a drum front brake, i would be willing to attempt the conversion to the rear axle.
Well you can't win with these things, they are so old fashioned, oil lines going every which way, carburetor sticking out the side, 1/2 hub brakes, oil pump you can't get to, can't get the rear head off, yeah the cable doesn't make sense but neither does much else about them. But that's why they ROCK.
