Last Post: Jollly Rogers
Last Post: mrmom9r
0 Hello from 1970s Wisconsin!
0 mode of failure
0 Moto Guzzi V9 Bobber debut
Last Post: Bone
0 Best Tires to get 2017
Last Post: Four Speed
0 Replacement Fuel line?
0 Shotgun Porn
0 What do you think the wet weight of the Pan America will be?
Last Post: jammantoo
0 Cylinders and static compression checked. Advise?
Last Post: jordan1200
0 Cobra RPT Intake
Last Post: FearTheBeard
0 Dead battery cells - 1997 sportster 883
Last Post: jharback
Last Post: Vohnsen
Last Post: SoonerSport
0 Gravydog crashed again.
Last Post: ed_in_az
Last Post: salveson
0 getting this 78 back to the way it should be.
Last Post: DirtyCory
0 TC88A makes me smile until WOT
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: rj2
0 fat man on a sportster
0 Fitting 2003 sportster seat to 2004 sportster
Last Post: MudDigger
Last Post: SteveK
ziggyhd1 (60), greven (58), bliynd (33)
Crash7557's Avatar
Crash7557 Crash7557 is offline
Other Motorcycle Model: HD Sprint SS-250
Other Motorcycle Year: 1967
Crash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond reputeCrash7557 has a reputation beyond repute
Ok i got the tool from JIMS. Drilled out the stud on bike. Ran tap through to clean the threads. When i look into the hole it seems the first half of the hole is perfect. The second deeper half looks to have no threads. What is strange to me is that the deeper half has no threads uniformly around the circumference. Looks like it was only threaded 1/2 inch deep. Rather than full depth of 1 inch.
The stud screws in all the way too with no resistance and bottoms out at full depth of 1" (HD Stud).
Should I loctite it to death with high temp loctite? I figure if the threads are screwed up I'd need to pop the head to fix it either way so may as well get some more ride time before i have to do that.
Anyone want to shed opinion?
Sent using Tapatalk
"I love the mechanicalness of it"-Indian Larry
Subscribing Biker
I wouldn't loctite it, the heat will seal the stud in there. That extra space behind the threads, IMO, is so you can adjust how far in or out you want the stud and leaves space for a heli-coil if the stud breaks (just an educated guess).
harley506d's Avatar
Sportster/Buell Model: 1200c
harley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant futureharley506d has a brilliant future
Very interesting info on technical use of studs, you learn something new every day.
Has anyone got a spare cyl' head kicking around to see if this space at the back of the threads is normal?
Seems like the only thing stopping you from using the next size larger studs would be getting a wrench or socket on the nuts to tighten them, the way the exhaust flanges are constructed on a Harley. Has anyone every tried drilling and tapping the holes out to the next size that gives the threads a full bite. Seems to be plenty of meat in the head to go over-size on the holes. I never stripped any out, so it is just speculation. I have replaced bolts and studs in other equipment with the next next larger size. Using the drill and taps charts you could go to the next larger in either metric or SAE to get a good thread and it should solve the problem if the threads are damaged beyond any possibility of repairing them.
Using a special stud with the inner threads larger and the same stock outer might also be a possibility.
Graywolf
Sportster/Buell Year #2: 2008
Default Interference Threads Hold The Exhaust Stud In Place
Harley's interference threads hold the stud in place not loctite.
When I buggered up the hole a threaded insert was installed. That way the stock studs would fit.
Suggest making changes only where necessary. Bigger studs could cause other problems like fitting exhaust flanges to the head.
Crash7557's Avatar
I wish to restate that when I attempted to install the new harley branded stud, the stud did not fight or 'Interfere' on its way all the way to the bottom out depth of 1". This is why I am considering the use of high temp loctite here for 2 reasons:
0
Firstly, to reduce the torque exerted on he aluminum threads (which clearly have been reduced by the drilling) by increasing the surface contact area with the loctite. Stressing the aluminum more evenly when torquing down the exhaust flange.
Secondly, my intention is to use an interference threaded nut on the stud. I have used one before to replace a lost exhaust nut on this bike and they don't require much torque to move and they set in place solidly. In fact the other stud on this cylinder was using that interference nut and it had not moved a degree and came off W/O any trouble. Using these as replacements will reduce the required torque for the exhaust flanges to stay in place.
Lastly, since the threads are apparently reduced anyway, it will likely require an insert installed no matter what. Anything I do will just be delaying the inevitable. If it works then it works. On the other hand if it does not work and worst case the threads strip out then it was getting new threads anyway. Nothing to lose as I see it.
The odds of it working with these conditions are in my favor and personally i do not view any of it as an inconvenience to wait on the insert. To me i see it as getting the most out of it before necessary repairs.
Like going out and burning up a set of tires you know you are going to replace in a couple of days.
Does anyone agree/disagree with this line of thought?
Sent using Tapatalk
