0 Efi and carbs
Last Post: dieselvette
0 surges and/or hunting on 1200 EFI's
Last Post: Clevspeed
0 Could this be true?
Last Post: xena
0 Mandatory Motorcycle Inspections
Last Post: motorend
0 Hi
0 Clutch Spring plate poll
Last Post: xena
0 Can't get the free wiring diagram from HD
Last Post: RoadsterMike
0 Progress
Last Post: mickey t
Last Post: Weo
4 Hello from Chicago
0 Hi everybody!
0 Lowbrow XLR pipes
Last Post: A Seabee
Last Post: cazz1000
0 Bulbs
Last Post: shooterj2003
0 45740-62 & 62A differences?
Last Post: Fridge
0 Need to part with my '59
Last Post: cazz1000
0 When Were You Born?
Last Post: owlsplace
0 Question for RB racing exhaust guys/gals
Last Post: 883sporty03
0 Rear axle - what am I doing wrong?
0 Foot peg stud not lining up with motor cut out
Last Post: Thirdbrick
1 Pics of pets and what type of animals you have
0 What Petcock
0 Which cams ?
Last Post: Cumofo
richard rees (70), IRONHD1K (66), derekb (58), Hankrebel (43), CPurner (38), Vickers
Old 23rd June 2006
Turbota's Avatar
Turbota Turbota is offline
Default Installing an Oil Press Guage "How To" (w pics)
Oil Press Guage Install "How-To"
This install was done on a 04 1200R, but I would think that the procedures would be the same on the 03 and earlier Evo engines.
You will need 2 parts:
Oil Pressure Guage, Autometer,
White Face (can be ordered in silver or black face too), 0-60 psi, 1 1/2” Dia.
Drag Specialties P/N: 2212-0004
$ 22.68 + shipping from https://www.zanottimotor.com/shopping/partLookUp.html
Oil Press Guage Line, Russell,
Braided Stainless, (comes with fitting)
Drag Specialties P/N: 1204-8406
$ 38.40 + shipping from from https://www.zanottimotor.com/shopping/partLookUp.html
Here is a photo of the parts:
Note: The silver fitting is supplied with the Russell Oil Press Guage Line. The black fitting was bought from another source and is not needed, as it will not work with the Evo engine anyway (disregard it). It is hard to tell in the photo, but the Russell stainless oil press line is plastic coated just like the H-D stainless brake lines.
_____________________________________________
This photo was taken with the oil filter removed and shows the oil press switch (sending unit) that needs to be removed. The wire just pulls straight off.
This photo shows the new fitting installed into the engine case. Since these are pipe threads, use teflon anti-seize tape on the threads ... Attached to this fitting is another fitting that was once was screwed into the braided hose when it was packaged by Russell. The end of this smaller fitting screws into the other fitting and also has pipe threads and will need teflon tape ...
Note that this fitting has an AN style end on it that the oil press hose will attach to later. This fitting has to be at least partially screwed into the other fitting that attaches into the engine case [before] the complete assembly of both fittings are screwed into the case.
This photo shows both the oil press switch and the oil press line installed into the fitting assembly. Be advised that the oil pressure switch has pipe threads and will also need teflon anti-seize tape wrapped around it prior to install. As I stated before, the fitting that the oil pressure line attaches to is an AN fitting. These fittings don't use anything on them prior to install. [Nothing] on the threads. The stainless braided hose is zip-tied in 2 places as it routes up along the frame tube.
This photo shows the oil pressure switch wire. I routed it to the right side of the engine just so you could see it good. The problem is ... it is now too short and will need to be legthend just a bit. Since this is only a single wire, adding another section to the center of it will be easy. Just cut the wire, strip the insulation, and slide a piece of shrink tubing down the wire [before] you solder the ends together. Then slide the shrink tubing over the repaired section of wire and heat it with a lighter until is shrinks tight. Then push the newly lengthened wire on the oil press switch ... nothing to it
This photo shows the oil filter in place. As you can see, the install looks neat and the filter don't interfere with anything (if you look, I still have not installed the wire on the oil pressure switch. Got to get that done.
This photo shows the back of the guage and the mounting bracket I made out of 1" wide aluminum bar stock. Cost was $8 for a 4 foot piece from Ace Hardware.
This photo shows the guage mounted to the bracket. The hole was drilled just big enough that it would rest against the flat square section on the guage. Then the hose was tightened down which sandwiched the bracket between the square part of the guage and the hose fitting. What was nice was that once the hose fitting tightened up on the bracket, it also tightened up on the threads of the guage .... so. no leaks.
As you can see, I mounted the bracket to the "dog bone" engine stabilizer rod.
This photo just shows the top of the guage after it was mounted
The last photo shows the complete install from a distance.
That's All Folks!
04 XL 1222R
Old 23rd June 2006
grizz420's Avatar
grizz420 grizz420 is offline
Sportster/Buell Model: 05 1200R
Other Motorcycle Model: V star classic wife's
grizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the rough
very cool post a pic when you figure out a mount
05 1200R Forcewinder XR air filter, Mikuni HSR 42,Super Trapp 2-1 pipe,TC88a ign., head light visor, chin spoiler, sport front fender, solo seat off 883, 12 and 1/2 inch dual rate Works shocks , dual rate Works fork springs
Old 23rd June 2006
883 custom 883 custom is offline
883 custom has disabled reputation
Looks good,what kind of pressure readings are you seeing?
Old 23rd June 2006
chrishajer's Avatar
Sportster/Buell Year: 1988
Nice write up Ron. Thank you for pointing out the proper way to seal pipe threads and AN threads.
--Chris
Old 23rd June 2006
snowman's Avatar
snowman snowman is offline
Originally Posted by chrishajer
Nice write up Ron. Thank you for pointing out the proper way to seal pipe threads and AN threads.--Chris
I second that!!! Great job on the pics....
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 23rd June 2006
Turbota's Avatar
Thank's everyone ...
BTW, Either I have problems or these engines don't make much oil pressure.
My engine when very hot only makes 13 psi at a 950 rpm idle and 22 psi at a steady 3,000 rpm in neutral.
Mobil 1 15w-50 "red cap" if that really matters.
Old 23rd June 2006
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
This is why I stopped installing guages because it just makes me worry.
From 2005 service manual:
idle (950-1050 rpm) 7-12 PSI
2500 RPM: 10-17 PSI
2005 XL1200C
Those who trade liberty for security have neither.
Old 23rd June 2006
Cookiey_Man's Avatar
Cookiey_Man Cookiey_Man is offline
Sportster/Buell Model: XL883C Sportster
Cookiey_Man is on a distinguished roadCookiey_Man is on a distinguished roadCookiey_Man is on a distinguished road
Thanks Turbota for the instructions...excellent detail as usual...
One question:
... I will need to make a bracket to actually attach the guage to that screw you can see on the upper rocker cover .... that's the next project.
Wouldn't a mounting bracket afixed to the engine present a lot of shaking for the gauge? Make it difficult to read?
Cookiey
If practice makes perfect & nobody's perfect.... why practice?
Old 23rd June 2006
According to my '05 Service Manual...
Engine oil should be at normal operating temperature (230ºF/110ºC) for an accurate reading
At 2500 RPM, oil pressure will vary from 10-17 psi (69-117 kN/m²)
At idle speed (950-1050 RPM), oil pressure will vary from 7-12 psi (48-83 kN/m²)
Cookiey
Why do they put Braille dots on the keypad of the drive-up ATM?
Old 23rd June 2006
Turbota's Avatar
Well, I don't feel so bad now!
Thanks,
Jeeeze ... I wish my guage only indicated as high as 30 psi ... it would look alot better
