0 Jumping and rocking at around 3K rpm
Last Post: northern bobber
Last Post: Model H
0 Oil in air cleaner
Last Post: jazzman
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
0 I guess I'm back
Last Post: gravydog
0 ***DK Custom-Improved Front Suspension w/ Intiminator Fork Valves***
0 ***DK Custom Products is Now offering the Black Headlight Grille***
0 Some oil issues!
0 Battery reversed, bike dead
Last Post: Bow only
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: shooterj2003
0 Wtb - badlander seat for 1996
Last Post: slamtry
0 Hello from B.C. Canada
10 howdy from australia
0 Manifold -CYLYNDER head connection
Last Post: leon bee
0 1991 frame/engine original ground locations
0 1971 XLCH Project progress
Last Post: Whitewalls
0 Hello from mid Missouri
0 LED Brake light, surprising problem
Last Post: deuce460
0 Throttle Cable Adjustment Question
Last Post: deuce460
0 Sportster in custom softail frame
Last Post: deuce460
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
3 Wtb, Wts, Wtt, Wtg (XRs)
Last Post: Scott
  #61
Old 17th April 2013
Originally Posted by hellhound View Post
Ok I seen some of the pics on this thread and read almost everything but does anyone just have a straight up parts list with info about the brand of gauge, the length of the Russell braided line and anything else they feel is pertinent to this project.
I used this on the Fatboy. I'm sure they have one to fit a Sporty.
http://www.jpcycles.com/product/742-000
Old 17th April 2013
hellhound's Avatar
hellhound hellhound is offline
hellhound will become famous soon enoughhellhound will become famous soon enoughhellhound will become famous soon enoughhellhound will become famous soon enoughhellhound will become famous soon enoughhellhound will become famous soon enoughhellhound will become famous soon enough
I've seen that one before on JP and no it won't work, no one makes a decent enough kit
If your gonna blow it up, go big! Built, not bought.
Old 17th April 2013
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
The Arlen Ness kit is OK.
Folkie
South East England Riders
Old 17th April 2013
hellhound's Avatar
No way I'm spending that much tho, I like what u guys have goin on. I found the gauge in J&P, and the Russell line on another site for $47 cause that Harley shop that turbota posted isn't around anymore. So I'm wondering what else I need
Old 17th April 2013
hellhound's Avatar
Exclamation
Here you go:
See folkie I love what you did here with yours, but I'm going with an Auto Meter gauge and I'm wondering the length of your Russell oil line, everything else as far as fittings I've got.
Old 17th April 2013
Folkie's Avatar
Brass Nut
That's not mine; those are some of Turbota's pics which I had saved and reposted.
I used the Arlen Ness kit without gauge, and used a VDO (undamped) white faced gauge initially. The gauge didn't last long, and I replaced it with that one with an engine turned face that you see in the catalogues (which was oil damped).
Here are some pics:
You can't really look at the gauge there, except when you're stopped.
Old 17th April 2013
I would stick with an oil filled gauge.
Old 17th April 2013
hellhound's Avatar
Ok, that makes sense now. And my gauge is filled
Old 17th April 2013
Folkie's Avatar
Brass Nut
So would I, now. My original gauge didn't stop working, but the needle shifted. It read about 12 psi when the engine was off!
Old 17th April 2013
hellhound's Avatar
That's never good. I'm gonna do the same set up as the pics but I'm gonna use a different mount
