0 Iron-shed
0 Checking slow jet is correct size
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
2 My 1275 Hammer Conversion..
0 Performance valves and springs
0 Wtb--1967--1972 xlh
0 Frame bracket
Last Post: Skeezix
0 In case you have not seen Harley-Davidson's New Business Plan-
0 Clunking into 1st after Clutch is engaged and shifter is pressed
Last Post: DitchTBHSMM
0 New to the Chopper Lyfe
0 *DK Custom - Limited Time Sweetheart Deals - Save 10% On Select Items*
Last Post: brixtonanima
0 Too HOT to ride?
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
pwssr, petefwa, skeeter883 (68), roadogette (67), khaskins (62), iriegnome (55), sportster808 (52), ironheadmax (50), matt275 (45), DJb (44), HDFirefighter (38)
wally_m82a1 wally_m82a1 is offline
Sportster/Buell Model: 1200N
wally_m82a1 is an unknown quantity at this point
Question Nightster tyre type "-" or "B"
Hello. Maybe its a silly question but i cant find answer anywhere.
I want change front tyre in my 1200N. Service manual says it should be 100/90-19 but Michellin Commander ll comes only as 100/90B19.
So can I use bias ply tyre or i need stick to the diagonal?
Regards
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Year #2: 2017
they are the same
Thanks b0fh
