0 Adjusting Drive Belt While On A Lift
Last Post: hondo
0 Sportster Fork Upgrade
Last Post: Redbeard2
Last Post: davesz1r
0 Coil polarity
0 New Guy with Experienced Bike
Last Post: Bikeaholic
0 Info needed on mini sumps.
0 primary cover
Last Post: smoggy
Last Post: davesz1r
0 Chinese S&S carbs
0 oil transfer valve
0 Tappet blocks and tappets
0 Ground Up Beginner Build
Last Post: Edster
0 Sportsterpedia Progress
Last Post: hondo
0 "S" model specific Q&A
Last Post: Edster
0 80 xl1000 oil not circulating?
0 73 XLH Total Power Loss
Last Post: sleighcrane
0 Do you stare
Last Post: Oldmxdog61u
Last Post: BigLerowski
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
Old 15th June 2019
Calavera Negra's Avatar
Calavera Negra Calavera Negra is offline
Sportster/Buell Model: XL1200
Calavera Negra is an unknown quantity at this point
Default brake line length for higher bars?
Any one know of a guide that shows the proper length of brake line for certain rise heights? My current risers are 7.5 inches with a drag bar and I've gotten away with using the stock brake line on my 01 custom . I got the tracker bars that came off my buddies 48 that will add another 3 inches of rise and a bit of pullback. He gave me his throttle and clutch cables which are suprisingly pretty long but his brake line is different from mine.
So I'm looking for a brake line for 10.5 inches of rise. Any recommendations?
Old 15th June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Use the broom stick method and a friend with a piece of string, then measure it. Your best bet to be accurate.
If I had to guess, 4 inches longer than you are.
https://live.staticflickr.com/65535/...c4672303_n.jpg
