0 TC88A EX lower MAP settings
0 Hagerty Insurance
Last Post: Parker 1000
0 Wish I had a beach with a ocean
0 Does 20W60 reduce cam gear noise?
11 How much did you spend on accessories in the first month?
Last Post: ZCarFan
0 No juice, no run, no power, nothing...
Last Post: 81ironhead77
0 Poll: Saddlebag Supports
0 magneto twin plug heads
Last Post: marioserafica
0 Fun or money?
Last Post: bill smith
5 Wet Dream, Ever Have One?
0 Down on oil
Last Post: Billy1200
0 1968 xlch
0 blonde, brunette, red?
0 Hamburger drum brake clunk noise
Last Post: nickfracture
0 I'm here to introduce Gristle.
Last Post: apotheon
Last Post: Randy_rots
Last Post: apotheon
10 big bore question
0 Transmission figment
0 Smoke and top end job
win307 (66), JrzyDave (59), WeirdNJ (59), Pigskinner (46), jeepsoldier (44), Virgdog (34), bernardderek, John Titor (22)
Old 16th June 2019
northern bobber northern bobber is offline
Sportster/Buell Model: ironhead XLH
northern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to beholdnorthern bobber is a splendid one to behold
Default Jumping and rocking at around 3K rpm
My friend called me and asked to ride her bike to see if it was all in her head or does it act weird. I took a ride and have never experienced anything similar. 3rd gear@60km/ 4th gear@80 km/hr it begins to rock forth and back heavily. Its like a vibration but more aggressive. It does it almost in rhythmical sequences. Feeling like something going out of place. Like a gyro force, flywheel heavily out of balance type of feeling. But otherwise the bike rides strong and ok. Some sudden lean spot/reversion i could pick up but nothing else. I didnt have time to take carb or electrics or more apart at this point but thought i try to find some possible faults if someone might have experienced something similar. The chain was not too tight or anything like that.
90’s evo 883to 1200 conversion, hardtailed. CV carb.
Old 16th June 2019
A Seabee's Avatar
A Seabee A Seabee is offline
Sportster/Buell Model: Iron 883, now 1200
Sportster/Buell Year: 2012
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1959
Other Motorcycle Model: FLTR
Other Motorcycle Year: 2009
A Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond reputeA Seabee has a reputation beyond repute
can you power through it? or does it run out of power when this happens?
Old 16th June 2019
What year and model are her bike?
Old 16th June 2019
Yeah i can power thru it, it holds the power during the rocking and basically the power band is pretty normal. Its a hard tailed custom bobber. Engine -99 conversion from 883-1200.
Old 16th June 2019
Does it do it in 1st and 2nd gear, if not,then I'd be looking at the clutch/ primary drive chain and rear sprockets and chain for stiff spots. If it does it in all gears, then the transmission and gears.
Old 16th June 2019
Yeah i tried to reproduce the issue and i was able to do it in all gears i suppose in various amounts. Have to dig into the primary i guess.
I was thinking also about mixture or ignition issues.... but not sure
Old 16th June 2019
could be slide oscillation. has it been drilled??
leak in vac porting
Old 16th June 2019
The rear axle isn't sliding around in it's slots, is it?
Old 16th June 2019
leak in vac porting
The carb is not drilled i suppose
Old 17th June 2019
Was this bike operating 'normally' before this suddenly occured?
How long has the owner had the bike? (so as to reference observed changes)
What other service work (or accident or pothole, etc) did the bike experience before this started?
'rocking back & forth heavily' - Does that mean left to right? or surging power-wise? or engine only rocking forward & backward? or the bike jumping forward (like chain jumping cogs)?
