Keep & Kill
Last Post: gusm2
buddy (67), paulrainer (67), Pedrochellie, needweknow, BunnMan (49), SolariS (44), Doc69 (40), ftptptt1234 (40), dumbmxer84 (37), nhutch40 (29), XLButler (22), Ztomasc (22) |
4th July 2014
Posts: 111 Sportster/Buell Model: XL1200X forty eight Sportster/Buell Year: 2012
48 has mid-glide front end so triple trees are wider than normal sportster's narrow triple trees. And this why 48 has also different (wider) fork brace.
And the bottom half of the risers are integrated to 48's top triple tree. And the speedo housing has the upper half of the risers integrated. So 48's parts are not simple bolt on mods to other models. I think the new 1200C with fat front tire has also the same kind of configuration.
Here's one thread about converting from narrow to mid-glide front end: http://www.chopcult.com/forum/showthread.php?t=34954
4th July 2014
Posts: 3 Sportster/Buell Model: 883 Iron Sportster/Buell Year: 2010
Originally Posted by vaakko
Nice, good info!
I would just buy the good looking RSD cafe speedo mount or something similar simple bolt on mod
I was thinking the same thing..that RSD piece is really nice looking but expensive..(you get what you pay for though!) add the cost of an upper bar clamp you'll need and the idiot light kit and it add's up quickly!
4th July 2014
Posts: 236 Sportster/Buell Model: Iron 883 Sportster/Buell Year: 2014
I seen some one mount it to the eyebrow with some extensions maybe some one will chime in but im thinking about that way
a pretty chopped up 2014 Iron 883
6th July 2014
Posts: 401 Sportster/Buell Model: 1200C Sportster/Buell Year: '13
With Dremel work it can be done. With straight risers (of the correct height) your speedo could lay flat.
I did it to ditch the 'Custom' model riser. 2 1/2 " pull back risers are what I used.
Trust your Dremel work. Fit & refit.
I had to get the 48 light strip to fit the 48 'dash' lights.
Fits nicely overall.
Fire the motor, twist the throttle, life is good
7th July 2014
Posts: 54 Sportster/Buell Model: Iron 883 Sportster/Buell Year: 2011
As mentioned, you just need a dremel to trim off the edges of the risers. If/When you mock up the set-up, you will see what areas need to be trimmed. Just take your time with it...
8th July 2014
Posts: 37 Sportster/Buell Model: Nightster Sportster/Buell Year: 2011 Sportster/Buell Model #2: Firebolt Sportster/Buell Year #2: 2006 Other Motorcycle Model: Ducati Monster Other Motorcycle Year: 2013
Its actually a really easy mod to do. I put the Forty-Eight housing on my Nightster. Just remove the risers .. grind to fit and put it back together. Keep in mind you do have to relocate the headlight.
2011 Nightster / 2014 1190RX / 2013 Ducati M1100
10th July 2014
Posts: 738 Sportster/Buell Model: Iron 883 Sportster/Buell Year: 2009 Sportster/Buell Model #2: XLS Sportster/Buell Year #2: 1984
thanks dmhines, I had PMd you and found you posted this.
I do like the newer speedometer/tachometer that HD came out with.
2009 Iron [LIST][*]1250 Hammer Kit[*]30 degree reverse dome pistons[*]1.770 7MM Intake 4.520 TG Conversion[*]1.530 7MM Exhaust 4.610 TG Conversion[*]Striker Performance 7MM Valve Spring 550 Lift Triple Grove Locks/Beehive Springs[*]Competition Valve Job[*]560 Impact Cam Set[*]Bronze Oil Pump Gear[*]Dragtron II AC[*]V&H Shortshots[/LIST]
1984 Ironhead
10th July 2014
Yes .. much nicer than the standard factory speedo .. includes RPM, Speedo and Gear indicator plus you can change it to all different colors. I did not go with the Gas Gauge but supports that also if you buy the correct sending unit.
20th June 2019
Posts: 1 Sportster/Buell Model: Iron 883 Sportster/Buell Year: 2018
You can install 48 speedometer cover to 883. You need these parts from H-D shop, they are for sportster 48.
48's Cover 71988-10
48's Bracket 71980-10
and then you need rise the bracket for 3,4-3,5 inch so you need the 48's risers and small spacer ring at the bottom. The stock 883 riser is 2 inch and I bought LA Choppers Riser Extensions 1 inch For Harley Forty Eight 2010-2019.
Got it to rise for about 3,4 inch and did not need to grind oem risers or remove the headlight lip.
The speedometer and the indicator unit are same on both bikes so those are reusable.
20th June 2019
Air-cooled Forever
Posts: 3,040 Sportster/Buell Model: XL 1200 C Sportster/Buell Year: 2006 Sportster/Buell Model #2: (Prev.Own)XLH Milw.Spec. Sportster/Buell Year #2: 1981
Nice job!
