0 Mid or forward controls.
Last Post: rich56
0 I'm back...
Last Post: rich56
0 1967 Harley Sprint SS250
Last Post: Bigshankhank
0 Anyone Loking for a 250 Ninja?
0 Simplified Wiring and Bars
Last Post: wannabehero
0 Should I buy a Sportster??
0 Starter Help - Need Help Diagnosing
Last Post: hala_madrid
0 ultima electronic ignition
Last Post: Mission1
Last Post: rich56
Last Post: robbie202
0 Mid West Meet & Greet
0 Rear Rocker Gasket Blown
Last Post: Edster
0 did the quiet baffle install short shots
5 Tire Pressure?
0 Rubbermount Poll
Last Post: rich56
0 TC88A Maps for 883 to 1275 Basic Converstion
0 Charging
Last Post: jsandidge
5 1969 XLCH exhaust question
Last Post: 81Fe
Last Post: Oldmxdog61u
0 compression low?
0 mixing brake parts
Last Post: Randy_rots
0 Hello from the uk I just got my first Harley!
  #121
Old 21st June 2019
Most EI have instructions that can be found on the interwebz.
If you are having trouble IDing your ignition post a picture of it.
Someone here has seen them all.
Don't guess about the wiring get instructions or you will likely ruin what you have.
Some of the ignitions made are not worth using.
Old 22nd June 2019
zack74 zack74 is offline
Sportster/Buell Model: xlch 1000 rigid
Sportster/Buell Year: 1974
zack74 is an unknown quantity at this point
Thanks rick here is the pic of my setup.
Update, i am stic timing my bike and connected a test light +ve end to blue wire on the coil and -ve end to ground ,when i turn on the start switch the light bulb stays on, no matter how much i retard or advance the ign plate.Have you guys seen this before. Any help ?
Old 22nd June 2019
I'm not 100% sure what ignition you bought but assuming it's an ultima your coil hookup looks wrong. You've got one single- dual tower coil so according to the instructions the blue wire is not used and the pink and white don't belong on the same terminal.
See the dual-fire/single coil diagram in the instructions.
http://www.ultimaproducts.com/53-644_Ignition.pdf
Also instructions call for 2.5-3.5 ohm coil. Yours is 5 ohms. I'm not sure what problems if any this causes. Hope others will comment.
Old 22nd June 2019
Thanks needspeed mine is dyna s ds6-1 ign module and dual fire dc7-1 coil.
Old 22nd June 2019
Originally Posted by zack74 View Post
Thanks needspeed mine is dyna s ds6-1 ign ....
OK, I get it. Ignore my post.
Old 26th June 2019
Thanks to all the people who helped. It did enable a rookie like me to fix my bike. Reinstalled new coil and ign module. Static timed it,polarized the genny and the bike finally started ,no backfire or anything runs great.
Old 27th June 2019
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
