0 73 XLH For Sale, what's it worth
0 Nothing to See/Hear
0 Basket case
0 Oil leaking
Last Post: The Doctor71
0 Can't find where oil leak is coming from. 1200C
0 Chain drive conversion for 100+ horsepower??
Last Post: fafcpa
0 Just installed 70900274 combo gauge - fuel light stuck on
Last Post: Virto
Last Post: maltesefalcon
0 Starter wouldn't shut off
Last Post: XL1275
0 Tach/speedo
Last Post: Mluke33
0 Help Identifying Pistons
Last Post: Staffords
0 Riding pants repair?
Last Post: spoon
Last Post: bill smith
0 Howdy From Texas
Last Post: Veeflys
0 Stars and spanners?
Last Post: Meghanbrr
0 What Trips Do You have Planned for 2019
0 Replacement oil pump year 74
Last Post: Brog
0 1968 xlch
0 Slip on muffler
Last Post: Joe_jeep
0 Boring intro
0 Down on oil
Last Post: Billy1200
duckster (70), 1ST_SPORTY (67), stein (58), tanksgt (51), tompie (47), eness76 (44), watsone020 (42), bohagon (32)
Old 11th March 2013
Doc308 Doc308 is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Panhead EL
Other Motorcycle Year: 1948
Doc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of lightDoc308 is a glorious beacon of light
Very interesting. How do you get the rubber band adapters over the o-rings? Just holding the manifold with o-rings in place while installing clamps is even a bit awkward.
Old 11th March 2013
beardo's Avatar
beardo beardo is offline
Sportster/Buell Year: 2019
beardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of lightbeardo is a glorious beacon of light
What I do is, I install a band on a head, place an o-ring inside it. Install a band on the manifold, opposite, place o-ring inside. Start the manifold with the seals already on, onto the head. May need a small flat-blade screwdriver to work the seal around the manifold with the seal that was on the head.
Old 11th March 2013
DR DICK's Avatar
DR DICK DR DICK is offline
lets run two inner tubes in each wheel. in case one leaks.
D.D._____________________________-o&o____________________________
Old 11th March 2013
rangerman's Avatar
rangerman rangerman is offline
Sportster/Buell Model: Harley Sportster XLCH
Sportster/Buell Model #2: Harley Sportster XLH
Sportster/Buell Year #2: 1975
rangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the roughrangerman is a jewel in the rough
Great Ideal Dr dick I'm going to order two more inner tubes right now man why didn't think of this before I will never get a flat now.
When life gives you lemons squeeze them in the eyes of the people that doubt you.
Old 11th March 2013
now i'm,remembering a,post about a,belt,with suspender's.
Old 11th March 2013
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
Use the same procedure here, with clamps loosened and in place and also keeping in mind a little lubrication will help with ease of installation.
Really not that hard to do after the first time doing it, and seeing how it all fits together.
The thing about it is, when tightening down the clamps, make sure the width of the clamp is spread out evenly across the sealing gap filled with the O-ring, or it'll eventually cut the rubber band leaving a slit in it.
Old 12th March 2013
DR DICK's Avatar
hey rangerman is this post of yours the old -- you can lead a horse to water but you cant make him think-- line of reasoning?
Old 13th March 2013
beardo's Avatar
I get what you are saying. I also have never faught an intake leak since I started doing it this way. No shame in covering ones ass.
Old 14th March 2013
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
I never had any problem putting the bands over the orings, if you use the smaller cross section o-rings like in the James gasket kit. The Asian-made oring kits have the wrong o-ring, it is too large in cross section.
I cant tell you how I put them on exactly because it was such a non-event I dont remember. Just slid the bands up over the manifold or stub, cant remember which, then put the orings on in the normal maner, slid the bands into place, put the T-bolt clamps over top.
Never a mani leak since.
And yes, my grandpa was the guy who ran inner tubes in his tubeless car tires.
And he never had a flat.
Old 15th June 2019
shooterj2003 shooterj2003 is offline
shooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to beholdshooterj2003 is a splendid one to behold
We have ways to make you remember...
