0 Wont Fire up!
0 Ebay ****evil knievel bike****
Last Post: gusm2
0 clutch issue
0 Warm/hot kickstart
Last Post: Mission1
0 "S" model specific Q&A
0 N65C or N65A
Last Post: lespaul6
Last Post: Hellbent_4
0 XR mutt race bike progress
0 Top end failure
Last Post: Mission1
0 Rubber mount gas tank part
0 Coil polarity
Last Post: davesz1r
0 '86 xl1100 help hooking up lights
0 old style fender skirted
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
0 Ground Up Beginner Build
0 Sportster Fork Upgrade
Last Post: PetesPonies
Gold951 (69), tujbob (65), tcspannerwrench (54), rondog (51), scootsgal (49), barney27 (46)
Old 1st June 2020
bobber58 bobber58 is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to all
Default Wiring and the turn signal module
I'm going to do a custom wiring harness and need to know if the ECM will function properly with the TSM removed from the system. I do see a couple wires that run between the two, and dont see a reason why it wouldn't work fine without the module, but Harley does some weird things and you just never know.
Old 1st June 2020
How-To Eliminate TSM - Or Replace TSSM with TSM
http://xlforum.net/forums/showthread.php?t=847440
http://xlforum.net/forums/showthread.php?t=573200
