Last Post: clif02
0 2020 Sportster?
Last Post: Kbetts
Last Post: Cindy Dietz
0 Grounded
Last Post: JackFrost71
0 The one and Only O-Fish-shall Poser thread.
0 I guess I'm back
0 looking to swap mids for forwards
0 Riding in The Heat!
0 2003 XLH1200 - Tachometer died
0 Cold Start. Then stall
Last Post: Tucsonmax1
Last Post: Kennyv
0 The Rabbi
Last Post: wymanv
5 Your worst car?
Last Post: Tin Man 2
Last Post: Lone Rider
0 Occasional carb spit back, am I missing something?
0 1975 xlch1000
0 Sticky Valve fix
Last Post: JaKaL
Last Post: Bone
Last Post: farmall
0 "S" model specific Q&A
Last Post: LocoLocal
porch_hornet porch_hornet is offline
porch_hornet is an unknown quantity at this point
I wondered about the whirring sound too. I think it's the Andrews cams. I will say that I only put two quarts of oil in, as I didn't know how much was in the system. I'll top it up before I start it again. I sent the previous owner the link and she said it sounded spot on.
Sent from my Pixel 2 XL using Tapatalk
IronMick's Avatar
IronMick IronMick is online now
Rider Of The Iron Steed
Drain all of the oil and put in correct amount of fresh 50W oil, and a new oil filter.
You might also consider cleaning the oil tank with kerosene and a wooden scraper before adding the new oil. This should be done one time with any newly acquired vintage motorcycle. No need to do it again with regular oil changes.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
read up on this thread about kicker slip.http://xlforum.net/forums/showthread.php?t=1172767 slip is something you don't have to put up with.
Old 5 Days Ago
Mick, I changed out the oil to SAE 50. I also pulled the primary cover and discovered an issue. I'll be posting about that later and would love it if you would chime in. Thanks brucstoudt for the links on kicker slip. I'll be attending to that soon too. I got a new sprocket cover that came with the kicker support. Now I just need to figure out how to install it.
Old 5 Days Ago
IronMick's Avatar
Have you seen these Sticky threads? Might be useful info there...
Ironhead '77 & '78 Kick Support
http://xlforum.net/forums/showthread.php?t=721216
77/78 Sprocket Cover Support Mod for 23T ...
http://xlforum.net/forums/showthread.php?t=1533075
ok, the kicker shaft support from hell
http://xlforum.net/forums/showthread.php?t=520735
