Last Post: clif02
0 2020 Sportster?
Last Post: Kbetts
Last Post: Cindy Dietz
0 Grounded
Last Post: JackFrost71
0 The one and Only O-Fish-shall Poser thread.
0 I guess I'm back
0 looking to swap mids for forwards
0 Riding in The Heat!
0 2003 XLH1200 - Tachometer died
0 Cold Start. Then stall
Last Post: Tucsonmax1
Last Post: Kennyv
0 The Rabbi
Last Post: wymanv
5 Your worst car?
Last Post: Tin Man 2
Last Post: Lone Rider
0 Occasional carb spit back, am I missing something?
0 1975 xlch1000
0 Sticky Valve fix
Last Post: JaKaL
Last Post: Bone
Last Post: farmall
0 "S" model specific Q&A
Last Post: LocoLocal
fork oil change
Air-Cooled Forever
"UPDATE" Rode the same 200 mile route, that I rode a few days before the 'Fork Oil Change' and am happy to tell you'all that it was smoother and didn't bottom out, like when you hit a chuckhole with a skinny 21" front wheel.
Old 3 Days Ago
owlsplace owlsplace is offline
Sportster/Buell Model: XLH 1000cc
Sportster/Buell Year: 1981
owlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud of
Bravo... When I changed oil here I had to jack the front wheel off the ground to avoid fighting the springs. Not a big deal but not user-friendly either.
I may try this method next time. Or I may pull the forks and overhaul them and add easy-fill caps.
Sent from my SM-S767VL using Tapatalk
Old 3 Days Ago
Thanks for the update.
It's always good to hear when things go well.
Old 3 Days Ago
Bluto Bluto is offline
Another minor note, the fork drain screws are JIS, NOT phillips and it is very easy to strip the heads using a Phillips driver. If you don't have JIS bits or drivers in a pinch you can grind the tip of a Phillips bit and it will fit JIS screws much better. This difference has been causing grief when working on Japan sourced bikes and parts (like Showa forks) for many years...some info below from a tool vendor.
http://rtstools.com/jis-vs-phillips-...s-screwdriver/
