Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Lubrication and Lubricants
0 Am I missing a front wheel spacer?
Last Post: keithb
Last Post: KCinSB
0 Manifold to put EVO BT carb on ironhead
Last Post: Windtheropy
Last Post: Dave L
0 Speedo quits working, bike wants to die
0 The forum got talent
Last Post: Airbozo
0 new (to me) '82 25th Anniversary Edition XLH 1000
Last Post: frogg_nutts
0 Lost compression?
Last Post: sltm1
Last Post: conv90
0 Forks
Last Post: Diogenes415
0 watch what you ask for...
Last Post: lostNdallas
0 79 Engine Rebuild
Last Post: Peteroo
0 2013 Xl1200C all stock, Intake valve pictures at 30,000 miles,
0 Plug wire question
Last Post: Scuba10jdl
0 11:1 883-1200 build
0 Bendix Throttle Cable Mounting 74xlch
0 74 XLCH - a revival
3 How To Post Photos
0 Issue that has me stumped
0 Good Day eh
0 Rear brake help please!!!!
Last Post: RowJimmyRow
0 Harley being delivered next week
0 hey y'all
  #131
Old 27th May 2018
sportysrock's Avatar
sportysrock sportysrock is offline
Sportster/Buell Model: XL883H/1200H
Sportster/Buell Year: '96
Sportster/Buell Model #2: XLCH 1000 w/elec. leg too
Sportster/Buell Year #2: '72
sportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond repute
Originally Posted by Tucsonmax1 View Post
Maybe its just the Stick. When I changed the Oil and Filter, Put some oil inside the filter. And an additional 2qts in the Tank. The level was at the bottom of the factory stick when cold.
Ran it the other day for a few minutes in the garage. It was just above the Minimum line on the Temp stick. Gauge was only reading 70F or so.
Isn't the oil bag about 2-1/2 quarts? (usually anyway)
Ol' Big Daddy of the Dirty Ducks MC
I'll see your Twin Cams and raise you 2 more
Unlike the Internet, Al Gore DID INVENT Global Warming
Political Correctness never killed any terrorists.
Old 27th May 2018
Sportster/Buell Year: 2018
Tucsonmax1 is an unknown quantity at this point
My First Sportster. I was going by the book. 2Qts in the Tank. 4 Ounces in the filter. I used 2 Qts conventional 20/50. And topped off with Synthetic leftover from the Street 750. I changed the Oil and Filter at 500 miles. Weather has been bad. Always raining on my days off. Haven't been able to get it fully hot and check in the garage.
Tucsonmax1 2018 Sportster 1200 Custom, 2016 Hyundai Tucson SE AWD
Old 8th June 2018
Nibelungen's Avatar
that's it
summer
winter
Old 9th June 2018
Nibelungen's Avatar
Done some benchmarks... temps never goes over 100 celsius degrees...
Ergo..
20 degrees celsius less than before....
Old 9th June 2018
thermo wax pellet by-pass
less hassle unless you want maximum cooling
Old 10th June 2018
Nibelungen's Avatar
I had that on my former ride... which had the cooler mounted on scavenger line...
This time i leave it like it is... mounted on feed line... no thermostat...
i hope a cover in winter will do the trick... it is enough for burn condensation that temps rise over 70 celsius...
Tomorrow I am taking my Custom to the shop. Front brake issue. Its supposed to hit about 96F. Guess I'll see How hot it can go?
Saw it hit 210F this morning. Just under 90F at the time.
Today in the Heatwave hit 240F. Good thing I changed to Synthetic oil
Nibelungen's Avatar
Default An update on the OEM oil cooler without thermostat
It works fine and drop between 15 an 20 celsius less than before...
as said... as posted... a thick foil of rubber (now covered with aluminium tape) will cover the cooler when temps will drop...
Only issues can be riding for some time, like yesterday, under a big thunderstorm with heavy rain...
not that i do ride in these condition often (i'm careful and pay attention to prevent that... but it can happen... yesterday also there where many thunders, and in high mountain they earn your total attention... it's safer to stay riding on the bike, nonotheless i think if i was hit by one of these, my bike would be tranformed in an hybrid one)
in these condition oil temps dropped a lot... and also (obviously) you can't flog the bike... at least as long as they don't introduce a TC like any other bike of the same segment...
so...
without oil cooler under the rain in summer i noticed temps around 85 celsius...
with oil cooler, yesterday, temps where around 73 celsius... only a bit over the danger zone of 70 celsius (according to Mo.Co. specs).
In similar conditions it can be useful a manual bypass valve...
