0 TC Brothers weld on rigid on an early frame
Last Post: 71GCcuda
0 Burly Stilletto 13" shocks or ?
Last Post: clif02
0 Sidestand Extension/'Pad' ?
14 What made the best Improvement to your Sporty??
Last Post: wardie
0 switching from 16" to 18" rear tire
Last Post: wardie
0 Cobra fi2000 powrpro black
Last Post: RAIDER0372
0 Jiffy stand spring
0 Spokes or Mags
Last Post: d10221
0 Sissy bar and rack for 883
0 Changed The Fork Oil
0 Ironhead or Evo
Last Post: Andy Hog
0 is a buell a harley
Last Post: wardie
0 New guy
0 ‘72 Pinion gear question
0 When Were You Born?
0 ironhead oil pump pressure
  #451
Old 30th August 2022
Good.
I'm using a program called GIMP for animation and it's a learning curve.
Speeding it up 8 times was interesting but I realize that won't be very informative.
Old 2nd September 2022
Finally got this animation drawing finished.
I have to admit, after many measurements and checking,
I found that pump pressure does in fact run to the boxes.
I was under the impression for the longest that the oil path was block when the lifters came off the base circle.
That isn't the case, at least for 91-99 cases it isn't.
Once off the base circle, the path is very restricted, kinda like the smaller restriction I used in pump testing.
But pump pressure is never blocked entirely through the lifters.
edit:
I forgot to add the plunger spring so I added it and replaced the original I posted.
I did cut the spring away from the check valve since it got so busy there with the spring around the check valve.
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Wow, great animation.
John
Thanks. I actually enjoyed that little project.
Been wanting the ability to make animation for several years.
But I'm slow about catching on I guess.
Feel free to critique.
I did a good bit of internal gutting and measurements but the program I'm using to draw can't really use the dims.
So 2.38" becomes about 2-1/3 by eyeball. Then eyeballed to the next eyeballed part.
But the pieces are relative to each other as the cutouts went.
I'll post those pics as well.
edit:
Forgot to add these pics.
Old 23rd September 2022
Ok, I got hooked on the GIF thing and dragged through a presentation on hyd lifter noise on initial startup after replacing them.
Please check for accuracy and stuff.
This one caused the coffee pot to run dry.
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
Nice presentation HS
I like how you gerbilled the lifters open
reckon thin abrasive fiber wheel, appreciate the effort
Steve
'01 Cyclone stock
'13 FXDC 96" stock
Old 24th September 2022
Yeah I used a Dremil tool with a metal cutting blade to slice the lifter open.
That pic is actually the second one I did that way.
I found on the first one that the ID of the lifter body shrunk just enough to make it tough running the plunger back in.
But I got the same result on the second one so.....
I guess the heat involved in cutting shrunk the body a little.
Sportster/Buell Year #2: '03
my experience is heat would have an opposite effect.i think that removing approx.40% of the wall area caused the lifter o.d.to collapse slightly.and possibly the presence of a burr from the grinding disc..nice job with that anyways.
Old 25th September 2022
You may be right on that.
I did expect it to loosen the clearance before I cut it.
The dirty details are I cut the first one, filed the corners in case of burrs, then cut a 45 degree angle on the corners, then filed again, then honed the ID with sandpaper on a dowel.
Then still had some interference but less.
The reason I cut the second one was in all my windings, I lost the sharp details of the inside features.
So I cut the second one and forced the plunger in for the pics.
Showing the innards is what I was after anyway.
It's a tight fit but I can still force the plunger up and down by hand.
