0 TC Brothers weld on rigid on an early frame
Last Post: 71GCcuda
0 Burly Stilletto 13" shocks or ?
Last Post: clif02
0 Sidestand Extension/'Pad' ?
14 What made the best Improvement to your Sporty??
Last Post: wardie
0 switching from 16" to 18" rear tire
Last Post: wardie
0 Cobra fi2000 powrpro black
Last Post: RAIDER0372
0 Jiffy stand spring
0 Spokes or Mags
Last Post: d10221
0 Sissy bar and rack for 883
0 Changed The Fork Oil
0 Ironhead or Evo
Last Post: Andy Hog
0 is a buell a harley
Last Post: wardie
0 New guy
0 ‘72 Pinion gear question
0 When Were You Born?
0 ironhead oil pump pressure
Old 1st October 2022
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
With respect to the pushrods ...
  • All XL883 heads are 3.690" tall from the factory.
  • All 1986-2003 XL1100 & XL1200 heads are 3.690" tall from the factory.
  • All Buell XB heads are 3.670" tall from the factory.
  • All 2004+ XL1200 heads are 3.670" from the factory (these are XB heads with a little different machining and cosmetics).
When the XB heads came out in 2003, they were the first to get 3.670" tall heads, and they got pushrods with a different part number that measure .020" shorter than the other pushrods of the day.
Then when the rubber mount XL's came out in 2004, they got the XL version of the XB heads on the 1200 models and the new part number shorter pushrods to match.
What's odd is the 2004+ XL883's also got the new part number shorter pushrods, despite the fact that their heads remained 3.690" tall.
Anyway, the bottom line is that if you put XB heads onto a 1995 XL883, and make no other changes, you're going to get .020" more preload on the lifter. That's probably not enough to cause any issues. Might even help.
However, if you mill the heads any, and/or use thin gaskets, and/or do a valve job, that preload increases, and you could get yourself into trouble.
For a simple way to check lifter preload during assembly, go here: http://www.hammerperf.com/ttpushrodlength.shtml#method2
Click Here to Contact Me
Racepres Racepres is offline
Racepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud of
Excellent info... I'm thinking I saw this on yer site... But...was inundating myself in information.. Apologies for recovering old ground!!
I will be touching up the valve job... but...will measure stem protrusion before and after..
Hammer has different length Pushrods, great, as I prefer those to Adjustables..
Next Up.... Cams... Thinking S&S 500's
Thank You very much aswracing!!! Knew that you Knew
Sirrom1's Avatar
Sirrom1 Sirrom1 is offline
XL Forum Bronze Supporting Vendor
Sportster/Buell Model: 883L
Other Motorcycle Model: Bonneville
Other Motorcycle Year: 1967
Sirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud ofSirrom1 has much to be proud of
Default 1200 heads on 883
Originally Posted by Racepres View Post
Sorry... My Search Foo has let me down..
I do Not need opinions.. I am going to do this.
an XB12 top end Wholesale onto my '95 883.
the 883 has 45K on it, and needs a lifter..
I know about the breather modification.. any other pitfalls???
ie Pushrods? Cams of choice for a Hot street, occasionally Drag Raced, Build??
It "feels" like gasket set and Go......
Thanks
The combustion chambers of 1200 heads are larger than the 883. This is why 883 to 1200 pistons using 883 heads are not flat, but dished. This is why you cannot use regular 1200 pistons with 883 heads. The compression ratio becomes too high for street use.
You might want to evaluate this situation, difference in chamber size and resulting loss of compression with the 1200 heads, before changing heads with std 883 bore and pistons.
...I can't be outta gas,
I haven't turned around yet...
Again.... Replacing Entire Top End.. No Worries Mate!!!
