Last Post: XL Dane
0 33.4mm fork bushings
Last Post: 4cam
0 help with stuck engine
0 First start question
0 Starter Relay?
5 Rethinking 1250 Build
Last Post: Desertfox
0 1988 1200. Unable to get oil pressure. New pump, new filter, new pipes, new oil.
Last Post: Fivecats
Last Post: lehel
0 Sportster R.I.P.
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: speedyrette
Last Post: 99-883-c
FinnDRZ FinnDRZ is offline
Sportster/Buell Model: 883c
FinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to beholdFinnDRZ is a splendid one to behold
Default Power Vision map for Hammer 1275
Hi!
Converted my 2009 883c to Hammer 1275 (basic kit, no headwork or cams)
V&H shortshots and K&N air cleaner.
If someone has same (or almost same) setup, and will send PV map for testing? Just want to see if there is major differences in my autotune maps.
Thanks in advance!
Andy56 Andy56 is offline
Don't you get that from Hammer Performance?
All described here - http://hammerperf.com/ttinstallkit.shtml#Tuning
Yes I did, but I just want to compare my autotuned maps with other maps to see if there is some differences.
Here is my opinion...
Two customers purchase the exact same parts from Hammer to upgrade the exact same model of Sportster. I will stick my neck out and say Hammer will send each the exact same map. And despite what Hammer might want to call it that would be a canned map.
After the first 20 miles running you each enable auto tune. At that point any differences can only be viewed as "interesting".
It would serve no purpose to test the other guy's map.
Differences will relate to how well you can hit the many ve table entries but might also be due to environment and petrol.
Where a difference will occur in initial map is the choice each customer may make with air cleaner and exhaust system which Hammer may of specifically dyno'ed.
Yes, I understand. This is just to see if there is some major differences.
John Harper's Avatar
John Harper John Harper is online now
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Is there something particular you think you're missing in performance? I really can't see a slight tuning change making a "major difference" unless your existing tune is way out of whack.
John
No problems in my setup, the bike runs fine I'm perfectly happy
I'd just like to see other maps done with similar setup.
Does Hammer offer any different maps you could try?
John
I have not asked Hammer, I'd like to see other autotuned maps.
