Last Post: Akdawg
Last Post: Ironhead Max
0 Sportster Builds
Last Post: rsneha
Last Post: JimVonBaden
Last Post: Brad
0 Ironhead engine problem?
Last Post: Congojack
Last Post: CrustyTubs
0 Tachometer Suggestions
Last Post: BigMek
0 The Strociek Project
Last Post: CT XR rider
0 72 ih stroker advise needed
Last Post: rocketnorton
Last Post: ZTatZAU
  #161
Old 18th September 2021
Sportster/Buell Year: 1969
I can't begin to remember how many years I used plastic milk crates to work on bikes. I have a floor jack now. An actual lift would be way too professional for me. Make me think I was employed again. lol
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud ofGold Member has much to be proud of
Never even thought of milk crates. They're 12 in high though. I scavenged some cinder blocks from a dump a month ago. That will get me up 16" and be easier to go straight in with the trans while sitting down comfortably.
I bought some big screw eyes for the ceiling and next need some Harbor Freight tie straps to keep the bike from tipping off the blocks. The big jack I have lifts with 1/2" or so to spare, so that will work.
Right now the car is in the shop for the past week needing an A/C pump. I'd simply bypass it but they can't find a belt short enough. Just the pump alone is $850 for a hoopy Scion. A blown A/C pump clutch bearing will disable the car from even starting and make a loud as hell howl before it gives up. I could feel the vibration through the floorboards and steering wheel. When the bearing locks up it spins on the nose cone of the pump, wrecking it. It puts enough force on the belt to stall the motor.
My wife is really good about me spending money on the Sportster because she loves riding. It's me that is noogy about it.
Also need a new computer. A new artesian well pump would be nice. $3600. It still works but I don't feel we should rely on it at it's age. Probably will spend money on the bike before the well pump
Stop by my build thread:
http://xlforum.net/forums/showthread.php?t=2076933
Four wheels move the body. Two wheels move the soul. Three wheels move the bowels.
Old 19th September 2021
wedge's Avatar
wedge wedge is offline
I can't remember the last time I even saw a cinder block. Probably back in the early 50's. Nobody uses them these days because they break too easy compared to concrete blocks. Note: if you really do have cinder blocks, do not use them to support anything that you plan to get under because they will break and leave you pinned under the bike.
Old 21st September 2021
Thanks I checked them. They are concrete. You can tell by weighing them. Cinder is 28 lbs and concrete is 40 lbs.
My Dad always called them cinder blocks growing up, so that's why I called them that.
Old 24th September 2021
wedge's Avatar
Yes, they were a dark specked charcoal gray color and very light (as a kid I liked carrying them better than concrete ones). Your dad was most likely around when they still existed. They were never structural, they were always for landscaping or building sheds for animals as I remember.
