Last Post: Ron Bizzle
Last Post: XL Dane
0 33.4mm fork bushings
Last Post: 4cam
0 help with stuck engine
0 First start question
0 Starter Relay?
5 Rethinking 1250 Build
Last Post: Desertfox
0 1988 1200. Unable to get oil pressure. New pump, new filter, new pipes, new oil.
Last Post: Fivecats
Last Post: lehel
0 Sportster R.I.P.
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: speedyrette
Last Post: 99-883-c
  #31
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
I never go anywhere with out spares & a tool kit.
D-RAIL D-RAIL is offline
Sportster/Buell Model: XLH1200C
Sportster/Buell Model #2: XLH1000
Sportster/Buell Year #2: 1983
Other Motorcycle Model: FXD
D-RAIL is an unknown quantity at this point
Default Died while riding
So last night I was on a ride, about 30-40 minutes, all country roads so cruising around 80-90km/hr, when I start feeling the bike loose power (kinda like the feeling of loosing a cylinder and running off of one). The bike chugs along then cuts out and stops running - all electrical still working. I come to a stop, have a look, nothing seems odd so I fire the bike up with no issues. It runs smooth for another 2kms then does the same thing. That happens probably 4-5 times and then won't fire up at all.
I got it towed home and checked the spark at the plugs, both sparking fine, so that takes the ignition coil out of question at least while cold (could be faulty when hot). Any other ideas?
Thanks everyone!
Less is more! 2001 XL1200C
rejeanprimeau's Avatar
I will pull all the wires doing business with the ignition to check for a broken strand wire. By pulling, I mean to stretch the wire to see if the copper strand are still conducting the juice.
Intermittent trouble are mostly found there.
mjt754 mjt754 is offline
Sportster/Buell Year: 74
Sportster/Buell Model #2: Sportster
Sportster/Buell Year #2: 62
Other Motorcycle Model: Original flh
Other Motorcycle Year: 63
mjt754 is an unknown quantity at this point
Would definitely check plug wires and if you have old wires switch out. Feel the coil if excessively warm after it starts acting up would think in the ignition system and what ever you moved changing plugs might be a fault in the wires
Sportster/Buell Year #2: '03
Default any other ideas?
you just stumbled acrossed one.your ignition coil.works fine when cold then fails when the temp.rises.this has been found before.it's not uncommon.
Yep what Bruc said easy and fairly cheap not a valve ��
Thank everyone, I haven't had time today to narrow down the issue but I'm going to pick up a new ignition coil for the hell of it. Better to have it and not need it than to need it and not have it - or so they say. So IF the coil isn't the issue, eventually it will be and I'll be ready
You can check the coil for heat failure with a hair dryer - When the engine has been sitting cold - preheat the coil - then fire it up and see if it has issues...
For Sportster Tech Info:
1xl that is a cool hack I’ll keep that one
