0 U.s.m.c
Last Post: Bow only
Last Post: eskimo619
0 Side Car.
7 I met a living legend.
0 gas cap
0 Timing
0 Grrr..Bike just shuts off. No power
0 Powerraythor conversion
3 Shaky Dave Recovery
Last Post: SLW210
0 Riding in the rain
0 question about new trans door
0 Un-Block P-Bucket Pics???
0 Multiple timing marks?
0 Fuel gauge help
Last Post: stikflote
0 Handle bar diameter
RISport, Sleeper, Chaoszen (66), wojmc (64), Deicer18 (62), PhilR1957 (62), Bikerchk (62), bblbbl (44), 883Hugger (35)
  #51
Old 4th October 2019
There's another thing I found with the Rush mufflers. The baffles are pretty small compared to their advertised size.
On their 1 3/4" baffle the biggest OD socket I could run thru the baffle (have to have the baffle out and go from the inlet end due to the bar across the outlet end) was 1 1/8". 1 3/4" baffle with louvers deep enough its' actual ID is ~1 1/8". I got a set of 2" baffles. The actual core is the same but the louvers don't protrude as deeply. The 2" baffles want more fuel at larger throttle openings compared to the 1 3/4" baffles. The 2" baffles do seem a bit louder but they're deeper and less "sharp". They have a better tone. There's a section of solid wood slat fence I ride along leaving the area I live in and there's definitely less echo off it with the 2" versus the 1 3/4".
I'm not into LOUD pipes but I do like the 2" baffles better.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I was actually going to go with the 2" when I was considering them. Little deeper and louder.
The HP Plus baffles are all the same diameter except for the end they attach to the pipe/slip on to center them. Just different lengths. More golf balls as I call them.
Thought about cutting my current ones shorter. One golf ball at a time. Add more top end and a little louder. I've got another set here with 3 but for a 2" pipe. I think the ones in the slip ons have 5. The ones I had in my drag pipes had 4. The exhaust goes thru them and around them with narrower passages between each golf ball which is how they diffuse. They really are a unique looking baffle.
Old 4 Days Ago
motorend's Avatar
motorend motorend is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2019
Other Motorcycle Model: N/A
Other Motorcycle Year: N/A
motorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond reputemotorend has a reputation beyond repute
I just mounted the Khromwerks. They sound great and no decel pop. It seems the slip on part of the muffler is a loose fit onto the headpipes. I had an exhaust leak, so I loosened the mounting bolts and the muffler just slid right off even after having the clamps tightened. I applied copper sealant so I will test this morning. Also if your not running the muffler heatshield, the Khromewerks doesn't mate flush with the header heatshields. You will have that gap. The black is a nice match. Without having a wrinkle finish its as close as I think you can get to the same color. It didn't gray after last nights ride.
Old 4 Days Ago
NGOT8R NGOT8R is offline
NGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to behold
I wonder if you can have a muffler shop use their machine to squeeze the slip on portion of the muffler a bit to tighten the tolerance, so that it slips into the head pipe with friction? If so, this should allow an even tighter fit when you tighten/torque the muffler clamp. One last thing; I have seen where, sometimes if the muffler clamps are just tightened and not torqued to the manufacturer's or factory settings, they will remain loose and move around on the head pipe. Do you have any video of the bike idling or maybe even some throttle blips?
Old 4 Days Ago
60Gunner's Avatar
Chief of Security
Good deal. Nice deep rumble at idle that open up nicely when accelerating, huh?
I didn't have the loose fit but I did use new clamps and tightened good. I'm also not using stock headpipes. Cut my old drag pipes for headpipes but I'm not sure that should make a difference.
They won't discolor from heat.
Old 3 Days Ago
Make sure your clamps aren't slid on too far. They have to be where the slots are in the clamp area. The clamps won't tighten up the fit without those slots. Sometimes the slots need to be cut longer.
Old 3 Days Ago
60Gunner's Avatar
Chief of Security
Yeah, I barely cover the beginning of the slots.
Old 3 Days Ago
motorend's Avatar
I have them identical to how they were on the stock pipes. Flush. The khrome werks are set up identical to stock. The rear is fixed. I had to take the front back off today and add more high temp copper sealant. It’s setting. I will start it up tommorrow and see. It’s just a slight leak in the front. However, HD had that front one so cranked that the head pipe is slightly oval, as is the muffler that came off.
Old 3 Days Ago
motorend's Avatar
Default Rush or Khromewerks slip ons?
Really impressed with the throttle response and sound. I expected decel pop without a tuner, but nothing. They have a nice low rumble and are barely noticeable at cruising speed. I love the idle.
Old 3 Days Ago
Red hi-temp silicone will seal them up but it'll be hell trying to get them back off...
