0 Forward controls on a 2 into 1 exhaust system.
Last Post: exexpat93
0 MS rollers way too tight
Last Post: randy3934
0 Newbie
Last Post: wongjohnson
0 OEM Headlight Bucket?
0 Chris Farley Bike
0 Mid Control?!
Last Post: MikeBel
Last Post: leon bee
0 carbs?
0 Happy Thanksgiving
Last Post: bklyngeezer
0 Grateful Dead Timing Cover Source?
0 Halloween 1250 Conversion
0 Better Brakes
0 Northern Canada late 1950’s
0 Oil leaks
0 oil bag
4 1995 S2 buell
Last Post: J!nx
0 Spacer swingarm bearing
Last Post: eddie XLX
0 81 parts
Last Post: Andy Hog
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: Desertfox
0 XLCR replica in progress
Last Post: rg500
excel50 (79), blazer95 (70), mycle1000, Barryn37 (59), QBALL (59), paulieb (58), cfranz (47), BMXATV (46), ravyn3 (41), Texas_Wild, hillpope (38)
  #31
Old 18th October 2019
ParrotHead's Avatar
Other Motorcycle Year: 1974
Almost forgot to update this thread.
Sadly I only did 1,800 miles on my 2006 Sporty this past weekend, not the 2,000 I had estimated.
The good news is the clutch with the new XR1200 parts worked great. Not a squeal, chirp, slip, anything. I may do the same to my to my 2007 Sporty over the winter
John Wayne - "The Shootist"
[URL="https://chrisridingadventures.wordpress.com/"]Check out my Blog[/URL] for my trip reports:
[URL="https://www.buzzsprout.com/129999/841095-episode-170-interview-with-chris-comly-of-chris-riding-adventures-blog"]Click here [/URL]to listen to my interview about my Sporty and riding on the Motorcycle Men Podcast
[URL="https://www.buzzsprout.com/129999/2188085-episode-221-interview-with-iron-butt-rally-veteran-chris-comly?fbclid=IwAR2AuBjIEvI8AoLtC7ZCZ4VC5Er_Guo8WfaRjh-15tRD9a5_rLYlp_jdJBg"]Click here [/URL]to listen to my interview about the Iron Butt Rally on the Motorcycle Men Podcast
[URL="https://horizon.bmwmoa.org/episode-93-chris-comly/"]
Click here[/URL] to listen to my interview on the Chasing the Horizon Podcast
[URL="http://sportsterpedia.com/doku.php/start"]Click here for the Sportsterpedia![/URL] for technical information & advice
Old 21st October 2019
harley506d's Avatar
Sportster/Buell Model: 1200c
I have ordered the XR1200 clutch parts and just reading how to fit them.
http://sportsterpedia.com/doku.php/t...ef:priclutch02
Am i reading this wrong?
It say's to fit the bevelled spring plate with the inside diameter closer to the clutch hub and the outer diameter towards the pressure plate. The pic shows this the opposite way? Help, before i screw up!
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
I think you are misinterpreting the diagram, it is as you have stated "with the inside diameter closer to the clutch hub and the outer diameter towards the pressure plate"
harley506d's Avatar
But does it not show the outer diameter sitting closest to the clutch hub, touching the judder seat plate?
As the diagram indicates, you are looking at the top half of the discs - A bigger view would show the mirror (vertical flip) image of this at the bottom of the discs...
Look at the arrows at the bottom of the drawing...
The picture matches the description - In the picture, the base of the hub is to the right (and the inside diameter of the Judder Spring Plate is closest there) & the pressure plate eventually goes on the left...
Looking into the clutch hub (while sitting next to the bike), you will be seeing the Judder Spring Plate like looking into a cup (concave) - The rim is closest to you and the inside diameter is away from you... Of course, we're talking only a very small bevel here...
I'm not sure how many different ways to say it...
Bluto Bluto is offline
Other Motorcycle Year: 1973
The diagram above is correct...for another view and some text check out the FSM section for the XR1200 clutch also another way to orient the drawing above is to imagine you are looking at the clutch assembly from the rear of the bike.
FWIW the fix is still working well on my bike after 8 months ...
harley506d's Avatar
Ok, I see it now, and it will all become clear when the parts are in hand.
Cheers.
Old 26th October 2019
jzink0883's Avatar
Master Bike Builder
Sportster/Buell Year #2: 1998
At 15k miles, I replaced my stock clutch with a Barnett kevlar no-springplate kit.
QUESTION: Is there a compelling reason to go back to a stock clutch with the XR1200 parts?
Only reason I can think of is if there is a squeal. Interestingly Barnett used to supply a similar judder spring setup in their Sportster clutch kits but dropped it.
Old 27th October 2019
harley506d's Avatar
Picked up the parts yesterday. All in a bag so didn't check contents, got home and read my invoice and it said part no' 37913-90 qty-1. I thought hell, i now have to order another one. Opened the bag and found the packet had 6 plates in it!
Bit of a cock-up somewhere down the line!
